Do L92's need to be surfaced before install?
Old Mar 23, 2007 | 02:45 PM
1SickWS6's Avatar
Default Do L92's need to be surfaced before install?
I just purchased a new set of these heads and was wondering if they would need to be decked before install? I just pulled them out of the box and they look good, but I can feel VERY slight lines where they were cut previously from factory. I want to make sure I dont have any sealing problems with them, and was wondering if maybe a re-deck could maybe come out smoother?? I want to keep the chambers as big as possible.. I have a 6.0L with a forged bottom end and a turbo on it and plan on pushing a pretty good amount of boost with these on cometic gaskets (and a coat of copper sealer). Do I need to worry about anything?
Old Mar 23, 2007 | 04:23 PM
Richard@WCCH's Avatar
We generally surface all the L92 heads we do. A lot of the cores we've recieved have had some sort of nick or scratch in the sealing surface, so we generally surface all of them. Checking them with a straight edge would also help determine if you need to surface them.
Good luck,
Richard
Old Mar 23, 2007 | 05:04 PM
stevewix's Avatar
ditto, i thought the deck on mine looked like **** too!
Old Mar 24, 2007 | 10:45 AM
WKMCD's Avatar
With Cometics, I'd definitely surface them. Both sets of L92's on my engine were milled.
Old Mar 24, 2007 | 10:46 AM
1SickWS6's Avatar
Well I dont see any nicks or scratches.. I guess I will just check with a straight edge and go from there. Thanks!
Old Mar 24, 2007 | 11:01 AM
1SickWS6's Avatar
We posted at the same time, lol.. are cometics that touchy?
Old Mar 27, 2007 | 12:31 PM
1SickWS6's Avatar
Does anyone have any opinion on using copper spray gasket sealer on cometics?
