LS2 timing chain just bolts on ls1?
Old Mar 25, 2007 | 07:04 AM
Redlinez's Avatar
Default LS2 timing chain just bolts on ls1?
I saw another member with the LS2 timing chain on the LS1. Is this an exact fitting set up? I'm assuming it's a budget way to go?
Old Mar 25, 2007 | 07:47 AM
See5's Avatar
Yes and is good upgrade-
Old Mar 25, 2007 | 12:19 PM
TurboGibbs's Avatar
From my understanding the top gear won't due to 4 bolts vs 3 on the LS1 but the chain will work on the LS1 gears. I have an LS2 chain on mine. Someone correct me if i'm wrong on the first part.
Old Mar 25, 2007 | 01:52 PM
Hard Core Z28's Avatar
The LS2 chain and sprocket bolts right in.
Old Mar 27, 2007 | 06:02 PM
Redlinez's Avatar
Thanks.
Old Mar 28, 2007 | 09:39 AM
slt200mph's Avatar
LS2 chain is a up grade from the LS1 chain ... it is a direct replacment for the LS1 chain..and a bargan on top of that... $28 ...
Old Mar 28, 2007 | 02:25 PM
the_merv's Avatar
Veteran: Air Force
$28 from GM? How good is it, I was thinking of going with a double roller for my 402.
Old Mar 28, 2007 | 03:12 PM
slt200mph's Avatar
It is a lot more heavy duty than the LS1 chain..there should be some pic on here somewhere..they have been posted up many times
Old Mar 28, 2007 | 05:31 PM
the_merv's Avatar
Veteran: Air Force
Is it a Roller Chain, or the Stamped Steel..
Old Mar 28, 2007 | 05:49 PM
slt200mph's Avatar
Solid platinum and diamond encrusted ..they sure are purdy..
Old Mar 28, 2007 | 07:54 PM
See5's Avatar
If it were not too late I would go back to a LS2. It is a nice chain and it works with a split cover. I have never heard of a problem with one and have run them on two previous motors. My double roller has twice the slack.
Old Mar 29, 2007 | 12:33 AM
F8TEL402's Avatar
I have a single in my 402 with no problems..........
Old Apr 1, 2007 | 02:22 AM
the_merv's Avatar
Veteran: Air Force
So it would be good to keep the Timing Gears I am getting in the 6.0l that I bought, and just get a LS2 Chain and run with that..
Old Apr 1, 2007 | 06:47 AM
TurboGibbs's Avatar
Yes, the gears are the same or basically the same. Basically the LS2 chain link bars are made out of a thicker material. Less likely to stretch or break.
Old Apr 1, 2007 | 09:16 PM
4yall2nv's Avatar
i have a 6.o l also, would the ls2 chain just bolt up or would i have 2 change the gears? would chaging the chain by itself be enoguh for a 236/242 cam? or should i just buy the whole kit? thanks in advance!
Old Apr 2, 2007 | 08:07 AM
nmp27's Avatar
+1 here also!
