Rod clearances in a 6.0l Iron Block
LS1 Tech Veteran
Are you talking about the rods being in close proximity to the sidewall of the block or are you talking about the recommended oil clearance between the rod journals on the crank and the bearing inside diameter?
Steve
Steve
Steve
Steve
LS1 Tech Veteran
Typically, the LS series blocks don't have to be routinely clearanced for a 4.0" stroker crank like the Gen I/II small blocks did to build a 383. However, you should always check as a routine assembly practice.
I'm in the process of building a 408 myself. I haven't started assembly yet, as I'm waiting on a few more parts and waiting to take some vacation time to do the engine swap. I have a Callies DragonSlayer 4.0" crank and CompStar Rods. I plan on checking the rod clearances against the sides of the block as well as against the bottom of the cam areas and make sure that the reluctor wheel clears the number 8 piston (Wisecos). I'll check as to what is a reasonable clearance so that I can make a judgment. However, I think that it should probably be .1" to .2" or so to be conservative. If the windage tray hits the rods (or comes close) I'll just take a round nose body hammer and use a sandbag as a dolly to dimple the windage tray where necessary rather than shim the whole tray away from the crank. That way I won't shove the oil pickup inlet farther down toward the bottom of the pan.
I am going to run between .002 and .0025" oil clearance on rods and mains.
I don't know if this clears up anything, but I hope that it helps. I'm not saying that this is the optimal setup. It's just my plan of action and I'm sharing it with you as I've done a good bit of research on LS1 stroker buildup. Also, I used to be a diesel truck mechanic and I've rebuilt/assembled several engines in the past.
All my best,
Steve
All my best,
Steve
Originally Posted by the_merv
Basically will the Rods hit the sidewalls of the bottom of the Block?
I didnt have any clearnace issues on mine, BUT, it took me 10 minutes with an aluminum burr and I gave the block 8 extra notches in it just for ***** and grins..
If your questioning it, just fix it now!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
