ls2 head question
Old Mar 31, 2007 | 05:46 PM
Jrwood's Avatar
Default ls2 head question
Who much are used ls2 heads worth? Also, will they fit on a stock ls1 motor in a camaro? Thanks
John
Old Mar 31, 2007 | 07:19 PM
RGKSR's Avatar
Default LS2 heads
They are a direct bolt on to your LS1. They are the same castings (243) as the Z06's.
The LS6's have sodium filled exhaust valves, otherwise they are identical. Mill them down some (to raise the compression) and they are not bad.
Depending on the condition (miles/springs/etc) I would guess 400-600.
Bob K.
Old Mar 31, 2007 | 09:06 PM
Jrwood's Avatar
Thanks for the reply. I put them on who much gain can I expect over the stock ls1 heads?
John
Old Jun 11, 2007 | 09:45 PM
yobabiesdaddy2001's Avatar
what are the casting numbers?
