Need bearing help!
Old Apr 4, 2007 | 11:48 PM
streetwarrior's Avatar
Default Need bearing help!
Does anybody make a .020" main bearing with the chamfer (P-series) for a Lunati crank? My brother for some reason put a "Special" ported oil pump(insert your most caustic sarcasm possible) ported oil pump that ate itself into a slurry in about 23 miles. Needless to say, rotating parts don't run smoothly in a metallized lubricant, and the crank needed every bit of .020" taken off to get the grooves out. I haven't had any luck finding the bearings, does anybody even make them, or do I have a $2400 paperweight? Thanks guys!!
Old Apr 5, 2007 | 04:33 PM
Anyone? Normally by now there are like a thousand replies... nobody even wants to make fun of my brother?
Old Apr 5, 2007 | 04:49 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
"Scoggin Dickey Special"? Which pump exactly are you referring to? And if it did fail, have you or your brother already contacted us about the issue? Please PM me some details so we can look into this to help make it right. Thanks!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
