6.0/ L92/ L76 cam question
Going off the car craft article, 6.0- L92 engine build, will the 12499224 LS6 valve springs hold up to the comp cams 428-11, 228in/230ex@ .050 w/ .571/.573 lift? Some sites are saying they are only good up to .550.
Is there a better cam I should be looking at?
I would like to stick w/ the LS6 springs if possible.
Is there a better valve spring that I can run with the existing locks, keepers and seals, that won't break me?
So does the intake pushrod run at an angle since the rocker arm is off-set?
(valve train angles?) Can't seem to find a good pic.
I will be using the L76 intake also.
Car will be a 69 cam. prob a 4l60e w/ converter and 3.50 gears. Maybe a 6spd if one falls in my lap.
no the pushrod is in the same place its the intake valve that was moved out and that is why the rocker is off set.
I was thinkin about a standard split cam too. These L92s flow better than CNC LS7 heads under 4k rpm...i think. Thats a lot of incoming air, lol. I cant wait to hear what the real cam gurrus have to say. We're talkin about a stock 6.0 bottom end, right? Not a 408?
