C|alling Robin L. lsx questions?
anyway. just a few questions. this said guy ran an ls2 last year. is the lsx based off an ls1 or 2? what will this guy have to change?
also, when this guy orderes pistions threw dimond, will they need any special info beside the regular cc of the head bore strock ect? the block is pretty much the same as the ls?
also how much more does the lsx weight?
any inside infor i can get for this guy would be great to make his build go easy
edit.
what the biggest bore size?
The LSX , if you had to compare would be more like the LS2 in my opinion. It starts out with a 4" bore.
Stick with the LS2 Style front cover and cam sensor. I really don't remember if the block is able to accept the LS1 Style rear cam sensor. Not a big deal though.
Diamond knows what it takes to make any LS Series Piston. Talk to Mike Panetta. I work wth Mike on the pistons for my LSX Engines.
The deal with the LS and the longer strokes is the clearance for the counter weights and reluctor wheel.
I have not weighed the block yet (it's heavy) .
Max bore depends on what you want to run NA or power adder. The limit wll be dictated by the area between the bores. As you know the bore spacing is small and that area gets thin with the larger bores.
NA they say 4.250. My Nitrous engine will have a 4.185 bore. I would stay closer to 4.200 NA just to be safe.
Good Luck!
Robin
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
sounds like im in good shape because i have all my last years ls2 stuff.
it is heavy, but hopefully the weight will be over taken by the extra power.
thanks alot for your info. "my buddy" isvery exited to be gettingthis motor
I think Jesel is coming up with a retail solution to those that want a belt drive with coil on plug.
Kurt
Kurt
thanks for your info. im glad it is ls2 based because i have all ls2 covers ect, and my wiring harnes is set up for front mount cam sensor, and all should be good.
anyone interested in a ls2 block with one bad sleeve??
Kurt
Very interesting, any idea when that would be available?
Jim, The Jesel parts should be available soon, if they are not we will be making some adapters since the block can't run the LS1 sensor!
Kurt
Good Luck!
Robin
I also have a few questions.... I've searched all over the net and haven't found much.
- From the factory it is a 4'' bore?? I thought it was 4.125 bore from the factory?
- What machine work needs to be done before assembly? finish hone? If any machine work is necessary does the block need to be stress relieved prior to honing, etc.? I was under the impression that it was ready for assembly?
- Is there cooling channels between the cylinders? Will there be any cooling issues with light street use? EX.= Cruise nights or occasional street racing.
- I am converting over from a LS1. I know the block comes with a new cam retention plate, covers, etc. What else will I need to change? Sensors, wiring, oil pump, timing chain, etc?
Any info is appreciated! I will have this block soon and am trying to get a jump on the build.
Thanks,
Brian
That image says alot
Let me know if I can be of any help with your project!
Let me know if I can be of any help with your project![/QUOTE]
just a heads up doc, i figured this out last year when i went to the ls2, when extending your cam sensor wires you need to switch the outside 2 wires. i forget the colors, but im pretty sure it was the 2 out side wires need a swap from side to side.
good questions on the machine work needed. i will be boring mine out anyway, but what about the rest?
Originally I thought this was going to be a cheaper route than putting my Darton block back together? After the machine work, covers, sensors, gear set, etc. I'll have just as much or more in this LSX block. So much for saving a few $. I should already know that it never ends
I have Morel solid lifters. Now I'm wondering if I'm going to need to do any machine work to the lifter bores? Are the lifter bores the same as a LS1 block?
For MSD pricing, PM me so we don't derail this thread too badly
on the msd, i was looking at the new box for the efi. what one would i need to get? ls1 computer from a 98 with the new lsx block?
