LS7 Head Has Been Outdone!
If those deliver as promised you'll wish to have the $$$ to get some.
It also doesn't seem like the best design to have the pushrods at different angles, operating 2 valves at a time. Thats a lot more stress on all the components, including cam, valve springs, pushrods, ect.
IE: ET Canted valves flowing 422CFM out of the box, in a max config should be able to do greater than 900HP. There are already alot of 800HP combo's using this head...
1. Nelson Racing Engines Supercharged 406
32v SC Video
2. SAR's NewMad 502
Mal
http://www.hotrod.com/techarticles/1...s_engine_swap/
http://www.turbomagazine.com/tech/02...nycar_integra/ is an example of the v8 head on a billet 4cyl. block.
I also wonder why they went to 1.4:1 rockers. I understand the theory that it will take less lift to generate the same power with 4 valves vs.2, but would the extra lift from the 1.7:1 rocker hurt flow and power? Wouldn't the stock 1.7:1 ratio make even more power? Does the intake charge become turbulent at higher lift? Or what happens when you have 4 valves at higher lift? Does the divided intake port cause efficiency problems at the 1.7:1 lift?
As for RPM, I don't know why everyone thinks 10k rpm is such a big deal or barrier. 500ci Pro stock turns 9500rpm with the biggest longest valves you've ever seen. Cup motors turn similar rpm for 500 miles w/ flat tappets. Comp elim. motors turn a lot tighter than that. 500+ lbs of seat pressure fixes a lot of problems. 4v makes it easier, but I'd agree with Cary that it's not *always* better; but, if you put a company with equal amounts of engineering talent into designing a 4v and 2v piece for a given shortblock though..the answer is clear.
At any rate, LT5 zr1's are part of LS ancestory. Cossie Vega as well if you're gay. I'd regard "4v" and "arao" to be two different subjects. If you dis the company, that's one thing. To dis the technology is another.
The guy on the LT1 forum is getting a bit of flack from a few guys for trying something new, but he should be congratulated for fabbing and designing a cool piece..99% of the people on this forum buy cookie cutter parts and shouldn't be throwing stones.
I mentioned over there, we'll compare power between that engine, a couple other ls and lt engines of the same displacement and compression, and equal intake valve closing points. Overlay that with a Rippie or Lingenfelter built zr1 motor for kicks.
As for the legality of this engine in racing. The problem with the Batten 4v BBC heads is they were billet and not cast...otherwise they would have been legal in IHRA pro mod at least. As for the street markets...There's plenty of Bahrainians, raps stars, and drug dealers to sell too.
2.) When's the last time you saw a set of proper pushrods wear out.
3.) Alloys get thrown out most 2v needs to Ti to turn over 7500rpm anyway.
4.) Let's throw money out of the equation, because there's plenty of people that could afford "the best" whether it's 2v or 4v.
5.) Let's also throw out poweradders...that's not really the point because a guy could always put a power adder on a 4v engine too.
The real issues are this:
RPM: One issue is the valve float. Two small valves are better than 1 big one (every thing else being equal).
Flow: for a given bore size, 4v outflows two when designed correctly. Otherwise they'd be running 2v's in F1 and motorcycles right?
The big UNKNOWN issue here is the rocker arrangement. A Superstock Chrysler Hemi guy could chime in. Or A valvetrain design guy with the proper software could calculate the loads.
I don't know and you don't know.
Keep an open mind though. There's two types of people. The first type saw catheral ports for the first time and thought they were "skinny". The next type took the time to measure the cross-sectionals and based *potential* off the engine off that.
The all billet Dart LS block, $6k no problem.
All billet Wilson intake $3k, throw that on too thanks gotta have that.
$2k forged Lunati crank, pocket change what's a motor w/o one.
$10k heads whoa that's crazy.
If they cost $3-$4K he could not keep em in stock. The only question would be "How much faster would I go with 'em?"
Mal
