Stock Piston Rings Or File Fit!!!!!!!!!!
Old Apr 13, 2007 | 09:28 PM
fstls2camaro's Avatar
Default Stock Piston Rings Or File Fit!!!!!!!!!!
i got my ls2 honed and they said that it would still be stock size it is stock rods, piston, crank should i get the stock rings or aftermarket file fit ones it is a head/cam motor.also what rod bearings should i get and are the main cap bolts reuseable?does anyone know the ring gap sizes?
Old Apr 14, 2007 | 11:09 AM
Boosted LS1's Avatar
File fits will allow you to use the tightest suitable gaps. Stock rings will have even larger gaps after the hone by a factor of 3:1. Still be ok though. Stock rings are the easiest option so I guess it's down to how handy you are and how much time you have to file rings should you go that route.
Boosted.
