line boring!!!!!!!!!!!!!!!!!!!!1
Old Apr 14, 2007 | 11:10 PM
fstls2camaro's Avatar
Default line boring!!!!!!!!!!!!!!!!!!!!1
if i get new main bearings do i have to line bore?
Old Apr 15, 2007 | 12:57 AM
02NBMWS6's Avatar
glad you guys are rebuilding
Old Apr 15, 2007 | 09:37 AM
LSX Wizard's Avatar
If you're building a race engine, it's always smart to line hone a block after it's been run & heat cycled.
When using new aftermarket studs it's required due to the different stud material and different (increased) bolt torque - the bore changes size when you do this.
Other than this, simply installing new bearings does not require line honing.
