LS7 forged pistons - why?
Obviously, nitrous and/or forced induction almost demand forged, but normally aspirated there are a bunch of folks out there, including me, who have put a ton of hard use on stock hyperuetectic pistons in 346 bottom ends without issues ...
I'm trying to figure out what route to go for an LS7-style 427 - crate motor, or aftermarket short block with LS7 heads. The aftermarket short is stronger, but the crate motor is overall less labor to assemble/install. In either case, I would go with a fairly mild cam/valvetrain upgrade, such as Katech Torquer or LG G7x3, all of this for a '69 Camaro Pro-Touring build.
Thanks for any advice.
Of course, the aftermarket short block is likely more durable under some kinds of abuse, particularly detonation. The question for me still is, under the conditions I plan to use it, does the factory LS7 bottom end have reliability issues that are documented, rather than speculative? I wouldn't be surprised if there were real issues, but so far my searching of forums has yielded nothing conclusive ... Hence the question which will hopefully be addressed by the tuners themselves.
Did you go with an actual LS7 and convert to wet sump, or start with an aftermarket bottom end?
GM may have changed valve springs last year.
As far as I know...
No problems with the bottom end have been reported.
As far as I know...
Hence the thread: I appreciate that Katech does what they do for a reason, but that reason may have more to do with what's comfortable and familiar to them based on previous experience as race engine builders, than actual failures with the GM parts.
All that said, my likely plan from the beginning has been Katech short block, LS7 top end, and that's probably where I'll end up.
Thanks to those who've posted.
I've run both an 01 and an 04... Z06 for > 50,000 miles with ~ 26to 30 track days/year. I am an instructor, so you know the cars were pushed.
With the exception of safety equipment, brakes, track alignment and dot "R" tires, both cars were stock. Oh, and a Rippie combo heavy duty radiator/oil cooler was added to the 04. The 04 tended to run "Hot".I had a few warranty items, leaking left rear axle (both cars), steering box (on the 04), and right bearing assy ( on the 01), which were covered.
My 07 has also track prep'ed... so far no problems, but I only have ~ 4000 miles on her.
Gm's crate motors, LS6 or an LS2... would probably be my choice.
IMO, the LS7... is a bit of an overkill, unless you have made substancial changes to your Camaro.
Best of luck on whatever you decide to do.
Best of luck on whatever you decide to do.The car will indeed have substantial mods - a C6-vette derived front suspension and multi-link rear suspension from Detroit Speed, 6 piston/14" front/rear Baer Brakes, 275 front 335 rear DOT track tires, 6 point bar, substantial chassis reinforcement.
The goal is to be able to hang with a well-driven Viper or Z06. The '71 in my sig comes surprisingly close, so I'm figuring that 525 reliable rear wheel HP along with the suspension/brake mods above will make me a very happy camper
