main bearings!!!!!!!!!!!!!!!
Old Apr 22, 2007 | 01:47 PM
fstls2camaro's Avatar
Default main bearings!!!!!!!!!!!!!!!
do i have to get a line hone if i get new main bearings i didnt spin any bearings or anything?
Old Apr 22, 2007 | 04:44 PM
pist0lpete's Avatar
It wouldn't hurt anything but you definitely don't have to. If you wanna use main studs rather than the stock bolts you do need to get a line hone tho.
Old Apr 23, 2007 | 08:36 PM
Randy WS6's Avatar
use (plasta gauge) to check your clearance. This will tell you if your out of tolerance ,you can get it at any parts store. Try not to line bore if possible because this will cause your crank to move closer to the cam shaft ,causing your timing chain to lossen plus piston to deck height will change. most peaple that line bores has spun a main.
