LS2 injector size??
Old Apr 26, 2007 | 02:30 PM
fastbasser's Avatar
Default LS2 injector size??
What size injectors come on a 2005 GTO? What would I need to use these on an LS1? I have heard there is something different about the injectors. I just don't know what it is.
Thanks in advance for the assist.
Old Apr 26, 2007 | 05:31 PM
paco loco's Avatar
cant remember what the size is (i think high 20s) but the connectors, length and o-rings are different. the ls1's are called ev1s (manufacturing calls them mini-timers connectors) and the ls2's are called ev6s (manufacturing calls them uscar connectors). for the connectors you'll need these:
https://www.casperselectronics.com/M..._Code=newitems
the ls2 injectors are smaller in length by about 12mm; you'll need fuel injector spacers.
and the lower o-rings are different.
bottom line, i'd go with another choice (ford green tops). its a little easier going from ls2 style to ls1 style, but the other way is a little harder because i of the fuel injector spacers.
Old Apr 26, 2007 | 06:31 PM
See5's Avatar
33 pounds
Old Apr 27, 2007 | 05:28 AM
paco loco's Avatar
well i was a little bit off on the lbs
