445 ci LS2 with ETP LS7 Heads
Old Apr 26, 2007 | 05:30 PM
mxmatt137's Avatar
Default 445 ci LS2 with ETP LS7 Heads
After gathering parts and waiting a ton, the "red demon" is finally nearly finished and running. The car is a 2002 z28. m6.
Parts:
LS2 bored to 4.155"
Eagle 4.1" Crank
Compstar 6.125" Rods
JE Custom Pistons
ETP LS7 heads
LS7 manifold
Comp Cams hydraulic 244/248 duration cam (111 lsa)
1-7/8" Kooks Headers
3" ORY
SLP cat-back
17x11" rims all around
Hoosier autocross tires
...obviously, the list can go on and on, but that is all the main things.
We are hoping for around 700 horsepower and 600 torque at the flywheel. I'll post pictures of the motor and build up as soon as I can get them up.
Old Apr 26, 2007 | 06:27 PM
71CamaroLS1's Avatar
Very cool, I'll be watching this with interest as I'm building a similar combo ...
BTW, I think you meant to use 4.155 as your bore size?
Old Apr 26, 2007 | 06:33 PM
Juiced's Avatar
Is this a dry sleeve block? i sure hope so because if not i have no idea how you are going to get a 4.155 bore to make it a 445
Old Apr 26, 2007 | 07:17 PM
TAEnvy's Avatar
All the car needs now, as far as I know, is a TB spacer to clear the LS7 manifold, it should be driving by this weekend.
Old Apr 27, 2007 | 01:11 PM
mxmatt137's Avatar
Sorry, the bore is 4.155". It was started for the first time Tuesday night. After letting it cool overnight the headers, rockers, and a few other parts need to be removed to re-torque the heads(the fel pro gaskets need to be seated properly).
Anyways, the car should be driveable late this weekend. My dad is going to make a spacer for the throttle body and get a bracket to mount the throttle cable and then it can be put together and taken out for a drive.
I'll update the thread as soon as we get it running and let you know how it runs. At this point I'm just glad to see it on the ground for the first time since December.
Old Apr 27, 2007 | 01:18 PM
Stang's Bane's Avatar
How thick of a spacer? Where can I get one? I am doing something similiar.
What did you do for coolant crossover lines? Use Ls6 type? Sorry for all the questions, just want to be prepared
Old Apr 27, 2007 | 03:34 PM
mxmatt137's Avatar
As far as I know, the main things to watch for are as follows:
A.) The throttle cable/bell crank hits the manifold under WOT. This is an easy fix as a small (~1/2 in) spacer would allow the throttle to clear perfectly.
B.) A new cable bracket is required because the LS7 manifold has no throttle cable bracket.
C.) The LS7 intake required an extended map sensor harness.
D.) The ETP heads are taller and required longer plug wires. 6.0L truck wires are perfect.
E.) 1-7/8" d-port headers are required with the ls7 heads (different shape exhaust than other ls series motors)
...There may be other changes, but i'm not the one paying for everything so I can't remember every detail.
If you have more questions feel free to ask away.
Old Apr 27, 2007 | 03:43 PM
Thanks for the help!!
I am running factory LS7 heads and a coil relocation kit so that is taken care of.
I am running a Holley TB and it came with a bracket, still have to see if it works...
I guess I will have to have a fab up a spacer for the TB...
Old Apr 27, 2007 | 03:52 PM
Racin96ss's Avatar
Need Pic's
Old May 14, 2007 | 12:33 AM
WMSuperSport's Avatar
any numbers?
Old May 14, 2007 | 12:49 AM
beardWS6's Avatar
How is the motor coming?
Old Jun 9, 2007 | 01:30 AM
Any news?
Old Jun 9, 2007 | 01:46 PM
John B's Avatar
Moderator
Not true! My 1-3/4" stepped headers bolt up just fine to my LS7 heads and I measured both the inside diameter of the exhaust port and on my headers at the flange and inside tube diameter and noted 0.060" to spare!
Old Jun 9, 2007 | 04:23 PM
mike c.'s Avatar
Good luck.
Old Jun 9, 2007 | 04:34 PM
venom ws7's Avatar
What is the compression? 700 Flywheel shouldnt be a problem with that setup n/a.
PLZ Keep us posted the car should be a monster.
Old Jun 11, 2007 | 01:39 AM
MonkeyBoneSS's Avatar
sounds like a nice set up and of couse please keep us posted
Old Jun 15, 2007 | 12:44 AM
F8TEL402's Avatar
Any pictures yet??? we want ot see it......... post a you tube or something so we can hear it 2.
Old Jun 18, 2007 | 04:21 PM
Greg Fell's Avatar
subscribing
Old Jun 18, 2007 | 07:24 PM
LSmonster's Avatar
Parts:
LS2 bored to 4.155"
Eagle 4.1" Crank
JE Custom Pistons
ETP LS7 heads
LS7 manifold
3" ORY
SLP cat-back
I just finished a similar engine and it's ready for the engine dyno. 4.200" bore, 4.0" stroke = 443" It's a pump gas motor with a hydraulic camshaft and a Wilson billet intake. I think that 700 HP is a little optimistic for a pump gas hydraulic cam but we'll see. I think it will take more compression and a solid roller cam but I could be wrong. I'll post the numbers as soon as I have them. I'd post a pic of the engine if I could be it keeps saying the pick is to large to post... If someone wants to PM me there email address I'll send them the pic if they know how to post it....
Old Jun 19, 2007 | 06:17 PM
john_sblendorio's Avatar
what block / sleeves / insallter did you go with for the 4.2 bore?
