HELP!!!! Broke something at track tonight!!!
So I turn around to get my slip, car is sputtering real bad. I left and drove him. It smoked real bad on the way home. It is a ticking/hissing noise. I checked the code with my predator and it said engine cyl. misfire. I think i either bent a rod, floated a valve maybe, broken lifter, or maybe even blown head gasket. What does everyone think? I was surprised it still ran. Im also planning on putting a cam in it soon, so maybe I should just do it now and replace everything? Thanks. Last edited by Red99TransAm; May 3, 2007 at 05:57 PM.
I would pull all the plugs, the valve covers and pull the pushrods. Roll the pushrods on a flat surface to check if they are straight. Inspect the plugs for what color they are. light brown is perfect. oily is bad. If the electrodes are smashed flat you have had some piston contact (not good). From there you can determine how messed up things may be.
What was your redline set to?
hopefully its just something in the valvetrain, then its the perfect excuse for a cam swap
Sounds like more than just bent pushrod damage. Check your plugs & do a leak down test. Good luck.
