View Poll Results: What foundation block
Iron block
7
18.42%
LS2
15
39.47%
L92
16
42.11%
Voters: 38. You may not vote on this poll
Foundation (block) for next setup
Old May 4, 2007 | 07:22 AM
Steve Burger's Avatar
LS1TECH Sponsor
Default Foundation (block) for next setup
I am thinking the next setup will be either an Iron block, LS2, or L92. No LSX due to price. I want to use a Compstar 4" crank and rods, and solid roller setup. That's about as far as I have thought it through so far.
What block would make the best choice AND WHY for NA power?
Old May 4, 2007 | 07:40 AM
Bink's Avatar
I'd go with the LS2 4.125 Katech block - can''t beat their attention to detail and the prep work (vacuum impregnation).
Old May 4, 2007 | 07:56 AM
NBM2001z28's Avatar
Restricted User
LS2 - the research isnt all there for the L92 yet. LS2 can be done at a GOOD price and make GOOD power.
We can set ya up with something good Steve!
Old May 4, 2007 | 09:14 AM
383ss's Avatar
he's talking about a stock block, not resleeved.
I'm debating the same thing at the moment, but I'm going to use a stock crank. really, the only decision to make is if the extra 13 cubes is worth and extra ~500 or so. LS2 vs L92/LS3
no way would I do an iron block. way too much weight for no gain except that its the cheapest.
Old May 4, 2007 | 09:25 AM
Bink's Avatar
Oh, okay.
But why not go with the resleeved Katech 427 block??
Old May 4, 2007 | 10:29 AM
Wide Open's Avatar
I would go with the L92 block since it has a larger bore. It can use larger valves without shrouding.
Old May 4, 2007 | 10:36 AM
slow95z's Avatar
well since he said no LSX because of price then the katech block is out of the pictuire since its about 1000 more than the LSX.
Old May 4, 2007 | 10:37 AM
383ss's Avatar
Oh, okay.
since he said 'No LSX due to price' in the original post, Im assuming a block that cost more than an LSX would be over his budget.
Old May 4, 2007 | 10:43 AM
LS1TECH Sponsor
$$ That's why.
Old May 6, 2007 | 05:06 PM
Greg Fell's Avatar
the resleeved LS2's have a bigger bore and make more power, and not just because of the additional cubes. they un-shroud the valves more. they are also beefier when resleeved, i think most that have seen the L92's haven't been impressed with the quality (alignment of bores).
Old May 7, 2007 | 08:43 AM
LS1TECH Sponsor
I'm starting to think LS2 factory block. The resleeved option looks great but we need to do this on a shoe string. This build is about 2 years a head of schedule.
Old May 8, 2007 | 04:35 PM
Greg Fell's Avatar
if on a budget, i'd get the L92 for cubes and mainly to unshroud valves/heads.
Old May 8, 2007 | 04:43 PM
8ty8 LS1's Avatar
i'm going with a L92 with a 4"crank and 6.125" rods. definitely nice to have the extra cubes! good luck!
Old May 8, 2007 | 07:07 PM
yobabiesdaddy2001's Avatar
what is the most you can bore the ls2 aluminum motor?
Old May 12, 2007 | 11:54 AM
My90Iroc's Avatar
I'd say it kind of depends on what heads you're planning to use. If you're looking at the L92's then I'd go with the L92 block since the bigger bore will take full advantage of the large valves in those heads. If you're looking to use cathedral ports with typical valves then it may be worth the extra money for the L92 block, the LS2 will do fine.
People make good power with the L92 heads on the LS2 bore but it's my opinion that you'll see a sizeable jump with the bigger L92 bore. A big enough jump to be worth it.
BTW your old AS heads are doing fine. I think I finally got a clutch that'll let me see what the car can really do at the track. Thanks again.
Old May 12, 2007 | 12:25 PM
LS1TECH Sponsor
Good to hear they are doing well. I did not think I would be putting a new one together so soon.
I'm thinking High compression LS2 block, Big Solid Roller and ETP 255 or 265 heads.
I am not sold on the L92 heads yet. THe deck surface is too thin.
