What is the LS2 stock valve spring rate?
Old May 4, 2007 | 08:54 AM
rmpage's Avatar
Default What is the LS2 stock valve spring rate?
Can anybody tell me what it is?
I am trying to figure out how much stiffer a set of Comp 918s are, so if anybody knows the compression rates of both then that would be even better.
Thanks.
Old May 4, 2007 | 01:12 PM
PREDATOR-Z's Avatar
03+ LS6 springs(orange): max lift ~.580
O.D
I.D:
seat pressure: 90 @ 1.800
open pressure: 294 @ ?
Comp 918
Outside Diameter (O.D.): 1.290"/1.060"
Inside Diameter (I.D.): .885"/.656"
Installed Pressure: 130 lbs @ 1.800"
Open Pressure: 318 lbs @ 1.200''
Coil Bind: 1.085"
Maximum Lift: 0.625"
Rate (lbs/in): 313 lbs/in
Old May 4, 2007 | 05:23 PM
rmpage's Avatar
Exactly what I was looking for. Thanks!
