l76 injectors that came with intake, 39# @ 42.5 psi or 58 psi?
I set the injector flow rate tables with a peak of 39# for the 39# injector....but I couldn't find any flow data on the injectors only that they are 39lb..
Are they rated at 39lb @ 42.5 psi or at 58 psi? (most aftermarket injectors are rated at 42.5 or 43.5 psi.)
