Trick Flow 225 Heads
Old May 9, 2007 | 02:29 AM
tcr98taws6's Avatar
Default Trick Flow 225 Heads
Who runs these? Do you like them? Did you re-port them? I'm thinking about these on top of a new LSX block.
Old May 9, 2007 | 10:28 AM
iamsickofitall's Avatar
check out their new 235cc heads if you are going with a bigger cube LSX block. I would not re-port them since TEA is contracted to do all the porting on the TFS heads and they test their combos to just about every extent before calling it a complete product.
Old May 9, 2007 | 04:42 PM
SLowETz's Avatar
I'm running TEA/TFS 225's on an L92 416" bottom.
I'm happy w/my choice, but as already stated the new LSX block "may" justify the 235's.
Give Brian a shout and pick his brain-
Old May 9, 2007 | 05:52 PM
jeremym's Avatar
I ordered my 235cc a wk ago for a 4.060 bore. Brian and Mike can answer any ? u have. The 235cc just came out and they look bad ***. Look on TEA web page and check out the flow #'s. Almost 300cfm at 400 lift.
Old May 9, 2007 | 08:20 PM
HEMIETR's Avatar
I'm happy with mine. My combo made 464 on a Mustang Dyno. Small cam, stock block LS2.
Old May 9, 2007 | 11:10 PM
osuqsz06's Avatar
i got them for my car. i have a vengeance built 416 very similar setup to slowetz w/ exception of 6 speed tranny and slightly larger cam. mine will be dyno'd within the next 2 weeks.
Old May 19, 2007 | 01:14 PM
kwman's Avatar
Where did you guys order the 235s from? Did you have to call trick flow directly?
Old May 19, 2007 | 01:24 PM
osuqsz06's Avatar
call ron at vengeance!!
Old May 20, 2007 | 01:18 PM
jeremym's Avatar
Well my TEA/TFS 235cc heads will be here this Tues.
Old May 20, 2007 | 04:25 PM
XtrmLS1spd's Avatar
I'm definately going to get the 235's for my LS2 402. I was first thinking about the 225's, but I'll get more out of the 235's.
