Boring the LSX block
Old May 11, 2007 | 10:37 PM
Gordon0652's Avatar
Default Boring the LSX block
Boring the LSX block to 4.25" bore. Is that exactly safe? In terms of your engine breaking, and everythine else. If not, in your opinion what would be the biggest you would go to get the most ci?
Edit: All motor, no power adder.[SIZE=3]
Old May 11, 2007 | 10:45 PM
Tom@SpeedInc's Avatar
The most common piston size in that area is 4.185"
At the moment pistons and rings in larger bore sizes are custom. For that application should you choose Diamond pistons you would have to go with an inboard forged piston.
Just a heads up.
4.185 bore, 4.100 crank make you 451ci, able to use more shelf stock parts.
Old May 11, 2007 | 10:53 PM
Gordon0652's Avatar
Cant squeez any more safely?
Old May 11, 2007 | 10:55 PM
Beast96Z's Avatar
I wouldn't do it, at least not on the first go round. You'd only be leaving .150" of material between the bores, and while that may be enough for a solid N/A set-up, I wouldn't trust it under high boost or nitrous. Not to mention, if something goes wrong and you need to pull it apart, hone/re-ring etc., you'll be SOL.
Old May 11, 2007 | 10:56 PM
Gordon0652's Avatar
Forgot to say it will be an all motor engine. no power adder.
Old May 11, 2007 | 10:57 PM
Beast96Z's Avatar
You can, but he's saying that pistons wil become custom at any size larger than that, adding to the price. If I had one, I'd go 4.200' on the first round and no longer than a 4.125 stroke. You'd be looking at a safe 454.
Old May 12, 2007 | 12:16 PM
Quickin's Avatar
That would be a 457ci. I'm doing 454 with a 4.185 bore and 4.125 stroke.
Beast96Z,
Aren't you doing 4.185 bore x 4.125 stroke??? 454ci
Gordon0652,
Listen to these guys, there's no reason to have a ticking time bomb or an engine block you may have to throw away if you have a problem and have to rebuild it. Even if you go 4.250 bore and 4.125 stroke, you'll just have a 468ci. Thats only 14 cubes more than the 454 and at approximately 1-1.5 hp per cubic inch, you're only giving up about 14-21 hp. Not worth it.
Do a 454ci, you'll be one happy bastard with ~650 RWHP N/A and nice idle quality.
And my goal is also 700 RWHP, but I just don't think its gonna happen on pump gas and with a rather tame street car with 12:1 cr. 650 will happen, I'm confident.
Old May 12, 2007 | 12:34 PM
Gordon0652's Avatar
ok, it sounds like the 454 is going to be it, i have talked to engine builders today, and they agree with some of you, they like the 454 idea. Where can i get 4.185 pistons thoe? Diamond doesnt sale them.
There is a nother option, tall deck, a 495ci 4.185 x 4.50 or a 484ci 4.185 x 4.40.
Old May 12, 2007 | 01:01 PM
Quickin's Avatar
Your builder will be able to find every part you need, you don;'t need to make any phone calls looking for parts. And if you're gonna stay 100% N/A, your builder will offer a warranty with the engine and he will do all the parts ordering and building, usually 2yr/24,000 miles...IF you stay N/A.
If they don't offer that....DO NOT USE THEM...PERIOD.
Tall deck is great, and if you're gonna spend money for an LSX super-stroker, than you'll have the money for the custom headers you'll need to have with the tall deck, and any other custom made part. So it isn't a big deal, don't that petty stuff stop ya.
Go for it man.
Old May 12, 2007 | 05:20 PM
Beast96Z's Avatar
Beast96Z,
Yea, i knew it was more, I just didn't take the time to punch it in. As for my motor, it's a 4.155" bore x 4.185" stroke. I was looking for the most hp/tq in a usable range. That's why i went with the longer stroke.
Old May 12, 2007 | 07:57 PM
Quickin's Avatar
Whats up with your build? Do you have you Harrop yet?
Whats your opinion on the difference the Harrop would do compared to the Wilson or Hogan sheet metal intake? I don;t think I want to **** with the Harrop, seems like a pain in the ***.
Old May 12, 2007 | 10:38 PM
Beast96Z's Avatar
I'm still waiting on my valve covers from ET. I don't want to put the engine on the stand until I have every last part. You know how wait times are...... As for the Harrop, yea, i've had it for months, just like every other part for the motor. It really has been a drawn out build. Between manufactures unrealistic wait times and the slow overtime during the winter months, it's taken me awhile to get everything together.
I'd still like to see some results for the Wilson Billet intake. It's been lingering in the back of my mind if this Harrop things dosen't work out for some reason. I like the fact that it has longer runners, but I wouldn't buy one until I saw some results. As for your more traditional sheet metals, I'm not a fan. As always, they put up good big end numbers at the sacrifice of low to midrange power. It's completly out of the realm of my project. I want my motor to be done by 7k, and a traditional sheet metal would just be getting good. I hope the Harrop isn't as much trouble as people think there gunna be. If my 8 filter idea works, it should be a drop in.
Old May 13, 2007 | 01:18 PM
383ss's Avatar
diamond will make any size piston you want. just give them a call.
Old May 13, 2007 | 07:47 PM
WMSuperSport's Avatar
Give Erik at HK Racing engines a call. He'll have the most knowlege of anyone about building something extreme and reliable, like what you want.
HKRacingEngines.com
Wes
Old May 13, 2007 | 08:25 PM
skipperbisket's Avatar
HKRacingEngines.com
Wes
Erik is the best, however there are SEVERAL places that have just as much build experience as him. He's still the man
Old May 13, 2007 | 08:53 PM
Gordon0652's Avatar
alright, thanks for all the info.!
Kenny
