New TEA/TFS 235cc Flow #'s Check them out
#41
Originally Posted by jeremym
Does any body have back to back dyno results FAST vs Sheet Metal intakes? What is the goods and bads about both intakes for a street car?
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#42
Originally Posted by choppin-suey
so we got a set and flowed them on the same bench as we have flowed 20 other sets and low and behold the cfm was not there so I take some of those flow numbers with a grain of salt
#43
Originally Posted by Beast96Z
That's the point I was trying to make without being so bold. While the TFS heads do make the power, the diffrence between their flow data bench and a superflow are astounding to say the least. However, flow numbers sell heads on 90% of sales, so you do what you have to do. This is a perfect example of both sides of the table. If I told you your heads only flowed 300 cfm, you might not buy them based on that, but if 10 people made 500 rwhp with them, you'd probablly go ahead with the buy and overlook the numbers. It's funny, because based on the heads performance, I would buy them, but I also know how much error is in the flow numbers and it wouldn't scare me off, but it would others. Don't take it as bashing, because I praise the work/ power that's coming out of these heads, but when I see the threads were people say "my TEA/TFS flow this much", and everyone talks about how awesome that is, it cracks me up.
#44
I don't want to jack the thread but edelbrock has a new Super victor LSx intake on the way. The ports are quite a bit bigger then the victor jr. I am waiting to hear back on when they are expecting to release these new intakes. It might be a cheap alternative to a sheet metal intake.
#45
Originally Posted by 383ss
but the fact that they flow this well with only a 235cc runner is pretty amazing.
I made 550rwhp with the same runner volume on a head that only flowed 293cfm @ .600
#48
Originally Posted by Stang's Bane
See sig.....
#49
pm atvrcr, he went from a ported 90 to a spyder(not quite a sheetmetal intake but close) and he couldnt be happier
also not to knock tea/tfs heads but I was told I would gain 25 horsepower over my afr's and a atvrcr was told 10-12 with the trickflows so we got a set and flowed them on the same bench as we have flowed 20 other sets and low and behold the cfm was not there so I take some of those flow numbers with a grain of salt
The problem with flowing heads is that there are many variables introduced by the person doing the test. The type of entry used, clay or fixed, if the person plugged the rocker bolt hole, etc. One of the biggest problems we see is not flowing the heads on a specific plate with DOWELS. For example, we have a 3.90" LS1 doweled flowplate with a 3.90" bore sleeve we use to flow the TFS 215 heads, this puts the chamber EXACTLY where it would be run on the engine, and this is VERY important. We have a 4.03" LS1 doweled flowplate we flow the TFS 225's on. We have a 4.125" LS1 plate we flow this new TFS 235 head on. Most shops are not going to spend the money on 3 or 4 flowplates just to properly flow ONE type of head that is made, but they should.
The next variable is flowing the exhaust port with a pipe or extension. We flow our exhaust ports with a pipe, usually 5" in length and this will add approximately 30 cfm to a good exhaust port. A poor exhaust port will actually flow less air with a pipe, this is why we use one.
The next variable you have is the difference in flow benches. I have been using this Flowdata flow bench for 14 years, it has probably had 10,000 heads run across it, and a good percentage of those get reflowed. We've had Superflow benches that flowed 1-2% higher than ours and some that were as far down as 7-8%, so that is a HUGE spread in just what Superflow benches show for flow. Our flow bench is plus or minus 1-2% of AFR's, so it seems to be right in the middle of their advertised flow numbers.
The next variable on a highly "tweaked" head is the fact that the airflow characteristics of the air flow stream inside the port will change with changes in air density, that being the barometric pressure AND temperature. We flow heads at 70 degrees, some ports will flow more air as density increases, some will flow less, and it all varies by type of head and port. We like a port that is not sensitive to density, like this new TFS 235 port.
The last and most perplexing variable is the sheer difference we've seen in flowing a head back to back on our Flowdata bench versus our Superflow bench. We have ports that are within 1-2% on the two benches and some ports that are significantly different from one bench to the other. This is the least understood of all the variables, but one that I have a theory on. Our Flowdata bench pulls equally around the radius of the base plate and has a big reservoir at the base plate. A Superflow has the plexiglas plate immediately below the base plate and I believe there are eddy's induced in the small distance between the two plates causing these differences. The thing we like about the Flowdata is the heads that flow the most on that bench seem to make the most power, and that is the only reason we are flowing heads in the first place.
The bottom line is our best ported L92 heads with 2.16" intake valves flow in the 290-295cfm range @ .400", the couple of LS7 heads we have flowed went 300 @ .400", as they have on MANY benches, and this new TFS head is up there in terms of airflow with a much smaller 2.08 intake valve. So it seems to be a winner, but time will tell.
#50
nice sig but just as flow benches are off so are dyno's, there is only one way in determing the worth of a product in my opinion and that is the numbers it runs.
In fact it is all a progression
flow bench->dyno->in car at the track.
If run by an honest individual all of these tools will give a an accurate respresentation of the cylinder head. But we all know that flow does not always equal horsepower. True horsepower does equal better slips though.
I am in no means bashing TFS heads. They do seem to back up their flow numbers with HP.
BTW, the sig refers to an engine dyno, NOT a chassis dyno.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#51
Originally Posted by Brian Tooley
If this is the same bench that showed the TFS 215's to flow more air through the midlift than the TFS 225's? If so then maybe you should take the data you got with a grain of salt, it's just not going to happen when properly flowed.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#52
I agree that the track is the ultimate test of power, but to be able to run a car after every tweak is not very feasible. Also the difference in cars would make a true apples to apples comparison impossible.
BTW, the sig refers to an engine dyno, NOT a chassis dyno.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
#56
that *** doesnt answer the phones now for the dyno, no way we get something pimp like that for him to use ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#57
I have a set of these heads coming (Thanks Ron @ Vengeance) and will be doing some testing against other heads. This is not a "who's best" kinda test but it will be interesting none the less. I'm building three 404" LS2 block engine for this test and all three will be identical except for the heads. One will have the TFS 235's. One will have the E/T 245's and the last one will have the E/T 4.0" LS7 style heads. I'll use a Wilson billet bank intake manifold on all three with a 90mm T/B. C/R will be 10.25:1 running on 91 octane pump gas and the same hydraulic roller cam... All three engine will be run one after the other on a engine Dyno so there is no mistake... I'll post some pictures (if I can figure out how to shrink them) and provide a link to the Dyno runs once complete... I'm fitting in this test in between other jobs so give me some time to get them together... HP numbers should be around 600 for all three engines...
#58
I think the TFS 225's would be a better choice for a 404, the results of the TFS 235's that are designed for a 4.125" bore has shown less than stellar results on 4.00" bore engines. Let me know when you get ready and I will try to send you a set of TFS 225's if you want.
What cam duration and why such low compression? Thanks.
#59
I have custom pistons that deals very well with the shrouding issues of the big valve heads in smaller bore engines. Of course that will not change the fact that the cylinder walls will still be close to the valves but the Dyno results can not be denied. 600 HP with a 10.25:1 compression and only 26 degrees of total timing is pretty darn good. And you can hit this engine with a 100/150 HP shot of nitrous and not have to change a thing... All on 91 octane pump gas ta-boot. Sure, I could add more compression to my pump gas engines if the customer "demands it"... But it's just not necessary.
JMHO
