QTP LS2 2 Piece Timing Cover Now Available
Its finally done and ready to ship
LS2 Quick Cam Covers
![](http://www.quicktimeperformance.com/images/LS2cover_spot.jpg)
Finally, a 2-piece timing cover for your GM Generation IV LS2 engines.
Quick Time Performance Quick Cam Covers feature a unique 2-piece design that allows your camshaft to be replaced without pulling the crank pulley off of the engine. They are manufactured from heavy-duty, aircraft-quality aluminum and include an OEM-style crankshaft seal.
With the Quick Cam Cover you will not have to worry about dropping your rack and pinion steering to change your camshaft.
We make our own high volume pump which is larger than stock so the cover excepts large pumps. It can fit a double roller but since there is no slack in the double roller chain you cant pull the top sprocket off. Making the cam swap not so easy any more.
I would believe it would work on a LS7 with a wet sump not dry. meaning a LS7 with a LS2 cover.
They seal up very well. It has machined lips. Just apply some silicone and its good to go.
