My 427 built my W2W
Old May 29, 2007 | 10:20 PM
Vindication's Avatar
hahaha, im aware of that car. If you go on you tube there is a c6 car they re cently did and it made 1037 on the dyno with GT35s. I have no idea how much boost was used. At this point I just hope the motor holds and I can supply enough fuel. APS is going to release a fuel system with the kit. Ive asked about how much power it can support and Peter said 1000 hp. We'll know when its on the dyno.
Old May 29, 2007 | 10:24 PM
Louie83's Avatar
It seems that the LS2 has proven to hold up to boost very well.
Do you (and W2W) expect the LS7 to handle boost as well as the LS2?
Old May 29, 2007 | 10:53 PM
I would say we will have no isses. Not many LS7's out there with boost.
Old May 29, 2007 | 10:54 PM
Originally Posted by Lythropus
I wonder why people don't use aeromotive fuel pumps? I just got their recent catalog and you can basically buy everything you need from them besides "Bolt in fuel rails" for your application. A sumped tank with one of their 1400hp efi forced induction pumps and fuel pressure regulator should do you just fine...
aeromotiveinc.com/system.php
scroll down to "pro system efi system diagram"
speed inc uses alot of 60lb injectors on their set-ups with alot of fuel pressure...
I will ask about this. Thanks for looking out.
Old May 30, 2007 | 08:47 PM
peter@aps's Avatar
Hee you go, the latest underhood pic of the ZO6 twin turbo system.......some of the fuel system is visible and it will support around 1000 HP.
More info at ther link below, http://www.airpowersystems.com.au/corvette/z06.htm
Peter
Old Jun 28, 2007 | 09:23 PM
peter@aps's Avatar
Hi Guys, Here's the latest power/torque graph of the APS ZO6 twin turbo system on a bone stock LS7 engine on 93 octane fuel at 6.5 PSI, enjoy!
Twin GT3582R turbos at low boost.
Peter
Old Jun 29, 2007 | 01:24 AM
Quickin's Avatar
NRE has been using them for their TT builds for a long time. Takes time for things to trickle in around here.
Old Jun 29, 2007 | 02:12 AM
OneQuickCoupe's Avatar
Peter, Great power with the turbo's on a bone stock engine but those stock numbers are really low for an LS-7.
D.J.
Old Jun 29, 2007 | 07:40 AM
Tiago's Avatar
D.J.
dyno dynamics dyno will read lower then your standard dynojet. Expect the same difference to be made up on the higher #'s as well...
Old Jul 1, 2007 | 07:37 PM
peter@aps's Avatar
D.J.
I think you must be used to seeing those over inflated dyno jet power figures............lol.
Peter
