ETP...11 degree L92 castings (small bore)
Originally Posted by Anonymous
I thought the L92 heads were 15* like the LS1/LS2/LS6 etc... Correct
I thought only the LS7 heads were 11*? Close, 12*
So I was thinking that these ETP heads were an L92 design, but on 11* to enhance flow? Correct once again.
So which heads are which?
BTW what is the Deck Thickness on the ETP L92's vs the stock OEM L92 heads?
I have a H&C car, but shoot a little N2O now and then.
I am looking to upgrade my heads.
Originally Posted by Stang's Bane
Hope that helps
But then how will an L76 intake that is designed for a 15* head work on an aftermarket 11* head? Special gaskets? Spacers?
Aren't they rolling the head 4*?
What about the deck thickness? (for stability on the spray)
Yes, that does help. Thanks.
Deck thickness should be much better.
L92
It is all bolt on stuff. No rolling decks. It is a purpose built head. No spacers or any of that, It will even accept stock l92 rocker arms.
Originally Posted by 02SOMWS6
So my Tony Mamo ported 90mm Fast wont work with these heads? I make great power with a set of portd and milled 241's. These heads should put me head and shoulders over my current set up. What about harland sharp rockers I have now, will they work? Am I gong to have to sell all my LS1 stuff?
You'll most likely need new pushrods, rockers, and L76 manifold. You can sell your ported fast for more than you can buy the rockers and manifold together for.
Also sell your old heads with pushrods and you won't be that far off. Just head gaskets and tuning.
Marty
Originally Posted by john_sblendorio
Two questions:
1. is this basically the same head as the LS7 4.0, only for the L76 intake?
2. Why make these heads for a L76 manifold since it is clearly a bottleneck?
Marty
#32
The only problem with porting the l76 is that it is a 1 piece manifold, where as the fast and ls7 for sure are 2 piece manifolds. It is much easier to get in side of them and work. You shold have no problems portmatching the l76 to the heads, but beyond that, it could get a little rough...
#34
Originally Posted by hesham
so if i wnat to put the et 265 on my lq9 6.0 i should change my fast 90?
If you are running 265's you shold be running
a) sheetmetal
b) Harrop or other ITB
c) Ported carb intake (probably race only setup)
Also if you want to see the benefits of the 265 on a 6.0 displacement, you better be ready to spin the ever living **** outof that thing. 8K+ rpm's
#35
If you want to let them breath you will.
a) sheetmetal
a) sheetmetal
even if i had a twin turbos
i want to change my MTI stage 2r heads so should i go for the et 265 with the wilson manifold
or go with et 255 and keep my fast?
#36
If you are running twins and a shot, I would stay away from the fast.
Anything above a ET225, you will be choking it with the fast.
How much boost will you be running?? IMHO I think you will have problems keeping your heads down on any of them...
#37
until now i went 10 psi and i gined 600 hp and i will go for 20 psi and that will be my max
#40
and yeah, the FAST is not a good seal because of it being a 3 piece. You can run a LS2 ported intake.
