Buy a stroker or built it?
402 needs some good heads on it, 225's are great
short block 3600 i built mine for maybe 3000
heads if your on a budget you dont need 2500$ best of the best
i dont know what you S2 heads are but prolly better than stock so they would work.
sell your cam for 150 get a custom grind for 400. injectors 400
wait on the fast 90/90
NO ONE SAYS YOU HAVE TO BUILD THE BADDEST ENGINE YOU CAN AT THE DROP OF A HAT.
hell wait on the intake i spent 1600 on mine you could do it for 7500
so really all you need to do is get the short block injectors and cam then gaskets and use the rest of your setup till you can afford the COOL stuff. good luck man. trust me you will love the added displacment for sure
here is a thread i started kinda like what you got going on
https://ls1tech.com/forums/generation-iii-internal-engine/681884-just-idea-short-block-over-h-c.html
http://www.texas-speed.com/shop/item...mid=44&catid=3
http://www.texas-speed.com/shop/item...mid=45&catid=3
others make long block kits i just posted TSPs cause i had there window open. check around or call them
I think you should look in to a forged 347.
