PRC LS6 Stage 2.5 w. G5X3?
Will this combo work with an LS2 as far as PTV clearance goes? I'll opt for the 2.02" intake valves which should help a little, but just want to make sure before jumping in on this. Searched, but didn't find very much.
-Edit - and by clear, I mean NO flycutting
Thanks!
Thanks!
They are custom heads, built the way you want them. If you want them milled they can do it, if you don't want them milled then they won't. I would hope they fit on a LS2, they well the stage 3.5 LS6 fit on my friends 408 setup. Unmilled they should run with the G5X3 without flycutting. best thing to do is just call. 806-866-0734.
We can definately help put something together for you. When your ready just give us a call & we can setup a cylinder head specifically for your application!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
