Video of our LSX on the Dyno
Old Jun 16, 2007 | 02:07 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Cool
Old Jun 16, 2007 | 02:26 PM
jamesSS's Avatar
Awesome.
Old Jun 16, 2007 | 03:12 PM
TRW427SS's Avatar
Great Job Robin!! I Know your base weight is 2750lbs + 200lbs for the 5 speed transmission ,but what`s your total weight end up being for NPS?
Old Jun 16, 2007 | 04:12 PM
StevensBikes27's Avatar
how he do that i thought only bike go that high
Old Jun 16, 2007 | 04:59 PM
SOM 02's Avatar
thats just crazy. i want one of those
Old Jun 16, 2007 | 09:02 PM
Robin L's Avatar
LS1Tech Sponsor
2800 Pounds
That is if I gan get that light
Robin
Old Jun 16, 2007 | 09:17 PM
Ryan'sSS's Avatar
Mother of god. That is one sweet engine.
Old Jun 16, 2007 | 09:57 PM
TRW427SS's Avatar
Originally Posted by Robin L
2800 Pounds
Robin
Ok, so small block and nitrous base weight 2750lbs + 200lbs for 5 speed transmission -100lbs for OEM cylinder heads -50lbs for Pre 1974 body = 2800lbs. Small block = no adder for sheetmetal intake or 2 carbs like the big blocks! If you can't get that lite EFI + 75lbs to base weight 2875lbs total.
Old Jun 17, 2007 | 12:13 AM
98Z28CobraKiller's Avatar
Restricted User
Mid 7's with all the juice.
Old Jun 17, 2007 | 12:30 AM
Bring the Noise's Avatar
Would this be the same Nova that used to have one of the first BB 572's.
I remember tuning into Spiketv every weekend when they were ripping that thing apart and turning it into a quarter mile freak.
So how long before the motor goes into the car and will you be doing the test run's at the Memphis Drag strip?
Oh I forgot to ask...
Does this mean that you'll be getting back to the L92 in the near future?
I still believe there is a market for the AFM (DOD) performance cam's.
Both for the 243 style heads in the 5.3L line and for the L92 heads style 6.0L and 6.2L motors.
Old Jun 17, 2007 | 07:05 AM
Robin L's Avatar
LS1Tech Sponsor
Yes it's the same car. I now own the car and will test local when I drop the engine in. We have completely re worked the car. It is 25-2 and been re wrapped in the GM Performance Parts sceme.
I hope to be testing within the next week.
My GTO, L92 and other projects are on hold until I get this car at the track. THe DOD deal and the software shows some promise. I do feel as though it's going to be a little while before the numbers can justify going to market with the cams. I want to get that L92 on the dyno and play. Oddly my L92 GMPP Crate engine isn't DOD.
Robin
Old Jun 17, 2007 | 10:48 AM
  #32
ShortChevy's Avatar
The vid gave me chills, honastly.
Old Jun 17, 2007 | 11:46 AM
  #33
S1LV3R's Avatar
Robin
Did they just go over the top of the old wrap? Seems like it would be a pain to remove.
Old Jun 17, 2007 | 07:41 PM
  #34
WOTFMAN's Avatar
Here is a pull to about 8800 on the dyno. Peak power was 930 at 8400.
We will spray one stage when it's in the car.
http://www.youtube.com/watch?v=e8LjUQzJurs
Robin
That makes no sense at all that you wouldnt tune the nitrous on the engine dyno and get it where it should be on a predetermined pill. Whats the reasoning behind that?
Old Jun 17, 2007 | 08:29 PM
  #35
Wnts2Go10O's Avatar
hell be fine me thinks
you better have the shakedown runs taped robin...lol
Old Jun 17, 2007 | 09:34 PM
  #36
Sharpe's Avatar
*blacks out @ ~7900 RPMs*
Old Jun 17, 2007 | 10:25 PM
  #37
shoemike's Avatar
Ruthless
Old Jun 18, 2007 | 07:26 AM
  #38
WOTFMAN's Avatar
You have an engine dyno at your fingertips with possible EGT hook ups and instead of going that step further in tuning and utilizing you want to take hits on into the chassis. Not my way of thinking but to each his own.
Old Jun 18, 2007 | 08:01 AM
  #39
Robin L's Avatar
LS1Tech Sponsor
Your thinking is OK but unless you have a lot of experience it's not a good idea.
Yes we had EGT's and we also (not on that pull) had Wide Bands on each Cylinder. The EGT's are a good general tool. But you can get too wrapped up in reading the numbers.
The Stuska is a water brake dyno with a strain gauge. The way that it loads an engine is different than what the engine would see going down the track. The same can be said about a chassis dyno. On a Dynojet with a 48" drum you see how fast you can spin the drum up to a certain speed.
Don West (the dyno guy) has sprayed many other engines on his dyno. I know that many shops who specialize in Nitrous will test on the dyno.
My feeling is that there would be little that would apply to my tune compared to what I will see in the car. So why bother.
I have EGT's on each cylinder as well as a wide band in the car.
Robin
Old Jun 18, 2007 | 08:47 AM
  #40
WOTFMAN's Avatar
Robin
Im not familiar with a Stuska but I do know the Super Flow Dynoes well. And yes it would be tuned on the water brake...Sure the brake may not be the exact same load but I will say this..The tuneup that would be in it leaving the dyno would be far closer then just out of box jets. Thats a fact. You can fine tune it on the track. I prefer not to go into things blind.
Im still not seeing any reasoning that would stop me from using the engine dyno except that you are uncomfortable tuning nitrous. Its only gonna get worse in the car. EGT's are not getting caught up in the numbers if you know how to read them. You'd be awefully surprised to know what some big nitrous cars EGT's get if you dont know already. What do they read if you can share with us?
