lookingfor 400+ci shortbolck for boost
looking also to run something like 8:1-8:5 CR .
any advice? who has the best budjet shortblocks out there?
The iron block would be better for boosting plus you can get a new bare iron block for like $600-$700
And the l92 heads will bolt up to that iron block
Any 400 cid motor is going to be choked to hell with that little 76mm turbo though.
Marty
I would rather have the extra 93 lbs and piece of mind but everyone will tell you different.
Marty
To me it means using the stock GM crank that is strong and cheap,
buying $500 rods instead of big $ billets, and a using strong iron block.
In general I spend my money where needed, using some inexpensive
stuff that works when possible, and spending the big $ where it is REQUIRED.
I think that this is what Underboss was thinking.
You can spend $20k on the longblock if you want, but why?
FI is not cheap by any means, but you can build a good combo of reliable parts
that will run well without throwing caution to the wind.
