LS2 swap for LS1
Old Jun 19, 2007 | 10:25 PM
john yerxa's Avatar
Default LS2 swap for LS1
What kind of adjustments are needed if a 2001 LS1 SS was replaced by LS2 crate?
thks
Old Jun 20, 2007 | 12:14 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
RTMFS.... Joking.
Read here:
https://ls1tech.com/forums/generation-iii-internal-engine/659189-ls2-conversion-info-inside.html
PS: THIS IS A ******* PAIN IN THE *** TO POST! PS POSTS AREN'T COUNTING! MADE A THREAD ABOUT IT:
https://ls1tech.com/forums/user-support-resources/735044-post-not-counting-continued.html
Old Jun 20, 2007 | 01:24 AM
F8TEL402's Avatar
if you are doing a straight swap you just need to re-locate the Cam sensor and Knock sensors with extentions.
Old Jun 20, 2007 | 08:36 AM
fastGBcamaro's Avatar
Default sticky
Also check out the sticky in the gen III internal forum. It is titled LS1 to LS2 swap. I am in the process of doing this right now. It isn't much, but it ends up being a few more parts than just sensor extensions.
