L-92's w/ forced induction what's wrong?
Old Jun 28, 2007 | 09:25 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The turbo could be the problem. If you're getting excessive back pressure it will cause you to lose tons of power. NA$TY-TA had a GT47-76 on his 370 and had major back pressure issues. He switched to a S88 and see below:
Originally Posted by NA$TY-TA
15 psi of boost.
10.80@126 mph.
Even adjusted more the car would not make more then 15 psi of Boost.
After some testing it was determined there was a huge amount of back pressure using this 76mm turbo with my 370ci motor.
23 JUL 2006
Some people dont think the above with a 76mm Turbo is true.....
but this below proves it.......
My shake down Passes
http://www.stenodperformance.com/kyle.wmv
S88 88mm Turbo was put in place of the GT42-76.
14 psi of Boost
1.474 60'
6.47 @ 107.89 1/8
10.07 @ 135.55 1/4
1 psi less boost then the GT42-76 passes and ran .7 tenths quicker @ 9 mph faster.....
2nd pass.... in the vid... it was the last pass..
tried 22 psi and spun the tires....
3rd pass... really 2nd pass of the day.
1.45 60'
6.055 @ 120.97 1/8
9.263 @ 150.50 1/4
Out of gear the last 150 ft.
Old Jun 28, 2007 | 09:42 PM
Sharpe's Avatar
Old Jun 28, 2007 | 11:12 PM
M3 Muscle's Avatar
Is that yank 3000 setup for a turbo? A turbo converter needs to be setup a good bit different than a N/A converter. Might be part of the problem.
Old Jun 29, 2007 | 09:39 PM
phildo's Avatar
Ya it was built for the turbo.
Old Jun 30, 2007 | 12:02 AM
NA$TY-TA's Avatar
As stated above.... measure the back pressure.....
how does the car load??? should come up on boost nice with those gears and converter....
Kyle
Old Jun 30, 2007 | 10:24 AM
LS1curious's Avatar
sounds like its time for 72pph low z injectors and a Bigstuff or similar system. Also that turbo is just way to small.
Yes a turbo thats to small will kill power.
Originally Posted by phildo
I got pissed and pulled the waste gate hose off and let her eat while monitoring the afr. It made 15psi and started to lean out at 4200rpm. This was through full exhaust. My injectors are at 83% duty cycle at 4400rpm(mototron 60) with my meth kit(big nozzle 100% meth) Car felt o.k. I only reved it to 4500rpms. I have had alot of fast cars this felt like 450 to 500 rwhp. There was no tire spin! I am running a 4l80e,yank 3000 stall,and a 2:73 gear. This car is way down on power. I did notice the header wrap on the down pipe starting to burn or discolor. There is a big problem with it. My question is can the turbo be causing such a dramatic power loss alone or do I have a couple of issues?
Old Jun 30, 2007 | 06:47 PM
phildo's Avatar
Kyle
How are you gues measuring back pressure?
Loads o.k. I give it 50% tps and it spools pretty fast.
Old Jul 1, 2007 | 09:31 PM
NA$TY-TA's Avatar
Wire a gauge into the exhaust.... i have spare O2 Bungs...
Old Jul 1, 2007 | 09:50 PM
phildo's Avatar
I will find a gauge. What is a safe measurement?
Old Jul 2, 2007 | 11:34 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a 402 with Livernois stage 2 L-92's, 28cc dish pistons, Stock Gm multi-layer steal gaskets,l-76 intake, 76mm turbo .96ar exhaust housing, .600/.600 232/230 115+2. Is it the heads that are not performing? Did I figure out the compression wrong? Mis-matched cam? I am only running 6psi on it but it seems weak. It will not break the tires loose at 30mph. Just trying to use others experiences and knowledge to save some head aches. Thanks for any input.
If I were you I'd cross-post this in the FI forum, but just from reading over the years I think you are out of turbo. When you run out of turbo, a few things happen. You end up trying to push more air through the turbo than it can handle, which leads to (a) backpressure and (b) heat. Ultimately if you keep pushing it too hard you can create engine issues. I've been told that you should look for compressor maps, but you should also measure the backpressure if you don't believe it. Anything over 2:1 is problematic.
Now I'd leave the cam alone it's plenty big and a swap to something a lot bigger won't be necessary for your goals.
Is that a T4 or T6 flange? If you can only fit a T6 flanged turbo, you might want to caucus the FI guys and see if they think a T4 80mm or 88mm is the ticket.
I'm running a completely different combo from yours, I'm running:
GT47.88 T6
348ci, 7.9:1
234/234/113
AllPro heads
A2A
LS2
90MM
4" DP
26 psi, C16, 20 degrees of timing, 867rwhp
T400, unlocked
I built my car to be friendly for the GLD True Street class, and I already had this shorty, though I might go up to a 370ci if I can run it in that class.
But focus on whether you ran out of turbo, and go from there.
Old Jul 2, 2007 | 11:00 PM
phildo's Avatar
GT47.88 T6
348ci, 7.9:1
234/234/113
AllPro heads
A2A
LS2
90MM
4" DP
T400, unlocked
Thanks for the input. I know now that I should rebuild to a t-6 flange but I will do that over the winter. Right now I am going to try and find the best t-4 turbo I can. I think everyone is right am I have a back pressure issue. There is really no difference in power from 10psi to 15psi. Car comes on strong at low rpm's and light throttle. If I try to gas it harder it goes but not like it should and the engine just does not sound right. Kinda like the sound of detonation and the exhaust doesn't sound right. Going to look for evidence of a exhaust leak before the turbo. I am thinking maybe the pressure is causing it to blow out some where causing the noise. It does not do anything wierd at light throttle/low rpm.
I think I just need to suck it up and buy a turbo.
Old Jul 3, 2007 | 09:14 AM
  #32
HTMtrSprt's Avatar
Phildo,
How has this car been tuned? Are you running the stock PCM? If you had it tuned using a wide band in the tail pipe, you will NOT be seeing the correct A/F ratio! Turbo cars consume a greater quantity of fuel to drive the compressor (turbo) and a large quantity of that fuel is burned in the exhaust system. Measuring A/F in the tail pipe allows time for ALL the fuel to burn and show an artificially rich reading. You should locate the wideband about 6" after the turbo outlet. Testing has consistantly shown proper readings of about 11.5:1 at the turbo will read as richer than 10:1 at the tailpipe. If you can't get a bung in the exhaust at the turbo, you need to throw fuel at it until it goes off the chart rich. Keep adding fuel until it quits making more power and even then add another 5%. Hope this helps.
Old Jul 3, 2007 | 09:54 AM
  #33
qqwqeqwrqwqtq's Avatar
Fwiw all of the turbo cars that I have tuned read within a half point from the downpipe to the tailpipe. (comparing BS3 wideband to dynojet)
On cars with open downpipes where the dynojet probe is near the BS3 wideband, they read less than half a point from each other.
Old Jul 4, 2007 | 11:54 PM
  #34
phildo's Avatar
Originally Posted by HTMtrSprt
Phildo,
Mine is in a bung right after the turbo. Tuned with the stock pcm.
Thanks
