Need some advice on my broken 408 please
Does anyone have a clue how this happened?
Here is the link to the pix.
https://ls1tech.com/forums/showthrea...20#post7293320
I think the cylinder walls get distorted then the rings runs out of clearance forcing the crown to crack. The walls look thin in the LS7s. If you have a sleeved 408 this should not be the problem.
It only had 800 mile when it let loose!
So hope it gets better for you but these things happen to these motor.
