l92 on ls2 mill to 11 comp question
Old Jun 24, 2007 | 07:56 AM
Houston999's Avatar
Default l92 on ls2 mill to 11 comp question
guys how much should i mill the l92 to get 11:1 comp. with the stock ls2 motor?
thank you
Hany
Old Jun 24, 2007 | 09:11 AM
SS Enforcer's Avatar
I'd like to know this as well .
cheers
Old Jun 24, 2007 | 12:00 PM
Richard@WCCH's Avatar
You'll need to mill the heads approx. .035" to get the chambers to 64cc. That will net you just over 11:1.
Good luck.
Richard
Old Jun 24, 2007 | 12:57 PM
Houston999's Avatar
Thank you very mcuh Richard
Old Jun 24, 2007 | 07:46 PM
SS Blazer 07's Avatar
After doing this will the intake still fit? Will you need different size push-rods? Thanks
Old Jun 24, 2007 | 09:55 PM
nobreaks254's Avatar
what about using a thinner head gasket?
Old Jun 24, 2007 | 10:00 PM
LS1TA385's Avatar
Yeah i would like to know as well if milling .030 or .035 will require shorter pushrods
Old Jun 24, 2007 | 10:13 PM
Milling .035" puts you into an area between commonly available pushrod lengths. The amount you mill has a direct effect on lifter preload. There are other variables such as valve tip length, cam base circle diameter, head gasket thickness and lifter length. Different manufactureres making different parts can have tolerance changes that can add up to an amount that can make a difference in lifter preload. In short, there's no real hard answer. Without knowing any of the varibles, if it were my engine I would first check lifter preload with a .050" short pushrod.
Richard
Old Jun 25, 2007 | 05:58 AM
Phoenix_Master's Avatar
Would it be the same .035" if the block was an L98/L76? the block is basically the same as an LS2 right?
Old Jun 25, 2007 | 10:23 AM
If you mean the L92 or the L76, they are two different bore engines. The l92 has a 4.065" bore and the L76 has a 4.00" (the same as LS2). The swept volume is slightly different and therefore the compression ratio will differ slightly.
Richard
Old Jun 25, 2007 | 10:41 AM
WKMCD's Avatar
Richard
Hey Richard,
Still loving your Stage 2 L92 heads on my build. The car uses absolutel no oil and runs like a raped ape.
Old Jun 25, 2007 | 11:07 AM
Originally Posted by WKMCD
Hey Richard,
Awesome news Kevin.
Richard
Old Jun 25, 2007 | 11:18 AM
Thank you Richard
Old Jun 25, 2007 | 11:47 AM
Richard
This is with stock gaskets is it please Richard on the L76 block.
Also Phoenix_Master did mean L98 thats what they call the L76 motor with the DoD stuff removed here in OZ .... I kid you not . Rather confusing for you guys as it can get mixed up with the vette motor.
cheers
Old Jun 25, 2007 | 12:04 PM
Yup, thats the one my car has an L98.
Old Jun 25, 2007 | 06:07 PM
Mine Too ....
Old Jun 26, 2007 | 03:09 PM
Houston999's Avatar
Richard ,
will there be any piston the valve clearance problem when i mill the heads .035 and use this cam 215/230 .629/.592 117 LSA ?i have the stock bottom end right now.
Old Jun 26, 2007 | 04:34 PM
cheers
Gottcha! I was indeed thinking of the old Vette engine. Are the Vvt units available there too?
Originally Posted by Houston999
Richard,
That cam has a lot of lift, but the short duration and 117ºlsa should help keep the valves away from the pistons.
Good luck,
Richard
Old Jun 26, 2007 | 08:43 PM
Richard
Not yet Richard but we think it will be in a Cadillac to start with. Not too sure on all the details but as GM is a world wide company most engine combos should be available all over eventually. I suspect the LS3 will be the HiPo option for HSV and the L92 will replace our L98 when they refresh the model range.
Cheers
Old Jul 30, 2007 | 07:49 AM
Sorry for the bump but will milling my L92 heads to 0.035" have PTV problems with a 216.5/232.1 0.631/0.590 116 LSA cam?
Appreciated
