I am afraid to hit the nos button
Old Jun 30, 2007 | 09:41 PM
Silverado327blue's Avatar
Default I am afraid to hit the nos button
i have a 98 firebird 6.0 truck motor and 243 ported heads 585 cam flat top pistons 373 gears and longtube headers ls6 intake and lid with truck maf sensor. Ready to go 11.88 dial ins 114mph . I just put in a 150 shot of nos wet kit. with race tech fuel punp. 4 degrees out of the timing with tr-6 plug. I think it is ok but 10 bolt rearend I am afraid. 225psi cranking compression will it blow the heads off. thanks Let me know what you think
Old Jun 30, 2007 | 10:33 PM
1320FEVER's Avatar
No, your heads should be ok. Its actually the head gasket that usually blows. But you nothing to worry about on a 150 shot as far as heads/gaskets go. If your worried about the 10-bolt, just set your rpm switch up high to about 500 or more above your stall speed, that way, you'll hit the 10-bolt with motor only (until you get more courage).
Old Jun 30, 2007 | 11:21 PM
the car is fast na at 11.88 and with 150 shot of nos will the auto trans with a 2000 stall expold or a drive shaft twist off. I hope I enjoy the 150 housepower not wreck my cars trans and rearend. but I am sure going to try the button soon just to see what will happen.
Old Jul 1, 2007 | 12:57 AM
speed_demon24's Avatar
The floorboards are known for blowing out on our cars, once you add some cross-bracing to them you should be good to go. And the plastic intake manifolds can't take the pressure of nitrous very good, you should get an intake manifold saftey switch.
Old Jul 1, 2007 | 08:48 AM
should I get a frame connecter. should I go with 100 shot if the intake plastic is weak or will it hold 150 shot. what is a intake switch. I will spray maybe 5 times a year. I want to dyno a big number and then go with a 100 shot when it is done for car day to day driveing. The motor na is bad as hell 11.88 at the track is nice so I dont want a full race car when I am done but If I need something let me know . No stoping now. Kevin Wisc
Old Jul 1, 2007 | 09:06 AM
99FRC's Avatar
You'll get more responses to this in the nitrous section. Post it over there for some expert advice.
(edit) Nevermind... I just saw that you did.
Good Luck!
99 FRC
Old Jul 1, 2007 | 10:23 AM
Optimus_Prime's Avatar
I'm amazied there is only one fast and the furious referance.
Old Jul 1, 2007 | 05:45 PM
bo-da3na's Avatar
heey how ya doin,,, but u need to check out ur pistons metal and the piston rings freedom
Old Jul 1, 2007 | 07:59 PM
2005 ls2 stock corvette pistons and new stock rings. Is stock pistons ok with 150 shot or to weak. Stock rings gap I am not sure of maybe i better find out. what is good gap.
Old Jul 2, 2007 | 08:08 AM
bo-da3na's Avatar
i dont prefer using 150--Nos shot... on a stock pistons,, u'll need aftermarket pistons,ex TRW etc... n its important to check out the rings gab.. so to be in the same side use only a Dry shot which is up to 100hp,, n 2day later i'll tell ya the recommended rings gab
Old Jul 2, 2007 | 08:11 AM
00SS!'s Avatar
Just push da button! And don't forget to post pics of any carnage!
Old Jul 2, 2007 | 11:32 AM
I was wondering about the pistons on 150 shot. Maybe 100 shot is the way to go. thanks
Old Jul 2, 2007 | 11:39 AM
Chicago Crew UnderBoss's Avatar
Good advice especially since your own post makes it clear that you are worried about breaking important driveline/drivetrain parts with 150 shot. I would go no higher than a 100 shot (on a stock motor0 if I were you and make sure its set up and tuned by a someone who REALLY KNOWS what they are dong in the LSX world and has a proven track record (and not some alley mechanic using your car as guinny pig)!
Old Jul 2, 2007 | 11:53 AM
3stgstocker's Avatar
i sprayed 2 150s on a stock 98 for 2.5 years and never hurt anything with a hypertech programmer with 2600 convertor 373 10 bolt stock steel driveshaft and was 22 and 1 grudge racing with it it has a 255 in tank pump and longtubes with borla cat back tr-6 suck though went to cold autolite and never burnt another plug
Old Jul 5, 2007 | 07:31 PM
I tryed it today with the tran in 2nd and 40mph I went wot and I hit the button. Tires broke loose alittle cause I could see black marks in my rear veiw mirror. I like the nos button alot. I hope the car last but it is nice to have. Thanks for all your posts. Alittle lean at 13.1 so I order more jets from nitro daves. Next week for more testing
Old Jul 5, 2007 | 07:40 PM
waterbug1999's Avatar
If its lean, you can go up on the fuel side. that should richin it up a bit.
Old Jul 5, 2007 | 10:25 PM
Cheatin' Chad's Avatar
I hate you for calling it NOS....
I have sprayed 250@ a H/C,stock bottom end LQ9. Over 100lbs of N20 @250 and over 400lbs @150 and 200.
Get the tune right,keep up on maintenance,start calling it N2O or Nitrous,make sure all of the safety items and there and a 150 will do not damage.
If you call it NOOOOOOSSSSSSSSS and then spray it the Nitrous fairy will destroy your motor then pop out of the engine and violate you anally.
Good luck with that.
Old Jul 6, 2007 | 09:44 AM
PatsLS2GTO's Avatar
If it is a Nitrous Oxide Systems "NOS" wet kit I have no problem calling it nos
Old Jul 6, 2007 | 12:50 PM
slick1851's Avatar
Thank you sir, this thread was making my head hurt
Old Jul 6, 2007 | 10:30 PM
ls1muscle's Avatar
umm.. LOL
