LS1 to L92
Old Jul 23, 2007 | 11:02 PM
blueeyeddevil141's Avatar
Default LS1 to L92
Will the parts off my LS1 bolt up to a L92?
(Oil pan, front cover, lifter valley cover, pulley system, ect.)
Old Jul 24, 2007 | 07:50 AM
JoeyGC5's Avatar
Oil pan, rear engine cover, pulley system
Old Jul 24, 2007 | 04:26 PM
Besides the obvious like heads, cam, timing, ect. what else will I need?
Old Jul 24, 2007 | 11:03 PM
Will my LS1 water pump fit? Will a LS6 oil pump fit?
Old Jul 24, 2007 | 11:08 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
ls1 water pump will fit as well as a ls6 oil pump.
Old Jul 24, 2007 | 11:12 PM
So, all I need is a front engine cover and a valley cover?
How big of a cam should my 416 have? It is a street car, and I love a ridiculous idle, I want low-mid I guess. Basically from 0-100 and 30-120 I want to be untouchable.
Old Jul 24, 2007 | 11:56 PM
the_merv's Avatar
Veteran: Air Force
You don't need the Front Cover..use a Gen III one, the LS1 does not have VVT. All these parts are pretty much universal. I just got done building a LSX Mutt..
Old Jul 25, 2007 | 10:30 PM
drain89's Avatar
Are you sure? LSX and L92 are different animals. Everything I've ever read here says on non VVT setups you have to use the gen IV LS2 front cover on the L92 block since it's where the cam sensor mounts. The L92 block doesnt have the mount for it in the back of the block like gen III LS1 style blocks do, thats why it's in the front cover. You just use a cam sensor harness extension in an ls1 vehicle for it to work.
IIRC the LSX block can use either gen III or gen IV cam sensor setup.
Old Jul 26, 2007 | 07:21 PM
racecar's Avatar
Don't mean to hijack your thread, but I have a dumb question, if the cam sensor is in the front, will any LS1/LS6 cam work, is the pickup in the timing gear? How does this front sensor work.??
Old Jul 27, 2007 | 12:55 AM
drain89's Avatar
gen III's cam pickup is in rear of cam. sensor threads into rear of the block.
gen IV's cam pickup is in cam sprocket. the sensor is in front timing cover.
from my understanding the gen III style cam will work in a gen IV motor but the gen IV style cam won't work in a gen III.
