L92 into C5 problem
Old Jul 28, 2007 | 09:50 PM
JoeyGC5's Avatar
Default L92 into C5 problem
Sleep owns me, please disregaurd
Old Jul 29, 2007 | 12:35 AM
blu00rdstr's Avatar
I don't think you have a problem, that left hole doesn't seem to be needed.
Below, first is your picture, then same area of an LS6 block.
Old Jul 29, 2007 | 09:59 AM
JoeyGC5's Avatar
After mowing the yard for 8 hrs then working on the car for 7 hours, I had a brain fart This 90 degree heat sucks, especially in the garage.
Old Jul 31, 2007 | 01:34 PM
blu00rdstr's Avatar
I just noticed an article where they ground that boss off to make the motor mount flush against the block. It's an LS2 in a C5. You might want to check to see if the motor mount is against the block or if there's a gap.
http://www.vetteweb.com/tech/vemp_06.../photo_11.html
Old Jul 31, 2007 | 01:56 PM
JoeyGC5's Avatar
It's not, I'm going to mill the mount tonight after work
Old Jul 31, 2007 | 05:31 PM
See5's Avatar
Try this ^
Old Jul 31, 2007 | 05:42 PM
blu00rdstr's Avatar
That is a cheaper part to grind than the block.
Old Jul 31, 2007 | 05:50 PM
kcmags's Avatar
Originally Posted by See5
Try this ^
Thats what I did. Works fine.
Old Jul 31, 2007 | 07:35 PM
VortechC5's Avatar
Mine was done that way too.
Old Jul 31, 2007 | 07:43 PM
JoeyGC5's Avatar
Try this ^
Thats almost a mirror copy of it now
Old Jul 31, 2007 | 10:10 PM
kcmags's Avatar
Hope you wore your safety glasses!!! lol
Old Jul 31, 2007 | 10:36 PM
JoeyGC5's Avatar
30yr old Bridgeport, I needed a cooling fan ore than safety glasses
Old Aug 1, 2007 | 09:45 AM
See5's Avatar
Mine was with old Sawsall and old operator.
Old Aug 1, 2007 | 10:04 AM
JoeyGC5's Avatar
Beter than a flat file and a screw driver
