LS7 Supercharger Options
Old Aug 12, 2007 | 11:58 AM
scott_mckinney's Avatar
Question LS7 Supercharger Options
Hi. Is anyone out there running superchargers on their LS7 engines? If so, which kit are you using? Has anyone changed the pistons or upper end to accommodate more boost? If so, how do you like your kits & which pistons did you use? Please advise.
Old Aug 12, 2007 | 01:20 PM
Vindication's Avatar
Heard the Vortech is a nice unit. Probably my 2nd option.
Old Aug 12, 2007 | 01:42 PM
Hi. What is the maximum boost you can run with the Vortech kit or any supercharger? What all would need to be changed to run more boost? Please advise.
Old Aug 12, 2007 | 02:39 PM
GrnDragon's Avatar
You can check with Kenne Bell, they have been designing a kit for the C6 Z06 for the last couple months
Old Aug 12, 2007 | 11:37 PM
Hi. I do not see it yet on the Kenny Belle website, but I will look into it.
Any other options or suggestions out there?
Old Aug 14, 2007 | 07:46 AM
07BlueDevilZ06's Avatar
4-6 psi is what most of the manufactures are making there kits produce on the z06
Old Aug 14, 2007 | 08:46 AM
Ed @ Late Model Speed's Avatar
We're finishing up a 2007 ZO6 with a Procharger P-1sc-1, making a solid 6 psi , 600+ RWHP, with LT headers and high flow cats & X-pipe.
If you want to make more boost than that, I would definately suggest different pistons & rods, but once you change those you should be able to run a lot of boost.
Ed
Old Aug 14, 2007 | 10:02 AM
Hi. What pistons would you suggest? I would like to run more than 6 psi of boost...
Old Aug 14, 2007 | 10:53 AM
dlove's Avatar
there is a guy here running like 4.25lbs on a procharger and runs about 10.8-10.7 or so @ around 130+
