Another LME 454LSX with pics
Unfortunately my build won't be as aggressive as tcr98taws6. I was planning on a 427 build and things got a little crazy. Our goals are similar a very nice driving street car that my wife could drive if I let her
Components include:
GM Bow Tie LSX 454 CID Block
Callies Compstar 4.125" Stroke Crank
Callies Compstar 6.125 Rods
ARP Studs
Wiseco forged 4.187" 9cc VP's
11.68/1 Compression
Cam Motion Custom Cam 252/256 595/595 112 +2
Melling M295 Ported High Volume Oil Pump
Rollmaster Double Roller Timing Chain
TEA Stage III big bore 2.10 intake valve Paris port 317's
TPIS 90mm Intake Manifold
TPIS 90mm Throttle Body
85mm MAF
42# injectors from Speed Inc
Kooks 1 7/8 headers and catted Ypipe
SLP dual dual
T-56 just rebuild by Ellis at Speed secrets
Tex single clutch
My goal is 573rwhp and over 500rwtq. That would give me a nice inrease over my 388 all bore motor. Later I will do a ported fast 90/90 setup and hopefully get a few more horses. If I can get my goal with this setup I just don't see doing a different top end.
I should have the motor\tranny etc in this weekend. Then waiting on a start up tune from wait4meperformance and the rebuilt rockers from Harlan Sharpe. After a little bit of a bread in period I will have it Dyno tuned on the same mustang dyno I did with my 388. Can't wait to get the results.
I have more pics of everything assembled I'll post up tomorrow and by tomorrow night it should be in the car and a roller again, I'm just waiting on the balancer and the rockers to show up!
http://www.texas-speed.com/shop/item...d=709&catid=20
What did you say it was going in? Sorry if I didn't see it.
The engine, transmission and suspension are in the car. I should be getting the balancer and rocker arms today and hopefully have her running this week. I have Thurs-Friday off so unless something crazy comes up I should be rolling then drive it around for an hour or so then head to the dyno
I guess it part of the keeping the cost as low as they can while providing an excellent block.
You always have QTP for the two piece timing cover.
