Anyone Running T&D Shaft Mounts with ETP ?
I have a set of ETP225's for LS2 4" Bore. I just picked up a set of T&D Shaft Mount Roller's and would like to know if they will work. Anyone using a similar combo ?
They will not unless you shim the rocker stands aproximately 3/8 of an inch with a piece of bar stock and massage the shaft mount hold down bolt bolt holes. Also Exhaust rockers will be off center. The spacing used for the row of threaded holes in the head is different than stock because ET changed the valve centerlines.
I have already gone down this road with a set of jesel sportsmans. You will have to make up something to get the rocker geometry correct and live with the offset rocker arm to valve tip (not optimal), use stock rockers with the ET stands, or get off the wallet and order a set of jesel j2k's that are purpose built. Probably not the answer you were wanting to here, but it will probably save you some money in the end.
Thanks for the info !
That is correct, this is a set specific to the ET cathedral port heads (205 -245 cc runners) I don't have the part # handy, although they were featured in a GMHTP engine buildup article about a year ago. I think they were somewhere around 1500 bucks. I haven't ordered mine just yet, other more pressing issues at home have prevented me from doing so, but Christmas is coming! Call Jesel or ETP.
According to ETP ... Jesel, T&D, & Harland Sharp make a set of custom rockers for these heads. T&D are $980 ... the Jesel are about 1300+ I think I may just sell my T&D Rockers for the regular heads and stick with the stock rockers. I am running a twin turbo 408 application which means pushing past 7K rpm will never happen ....
Has anyone seen any dyno results going from the stock rockers to a full roller on the ETP 11degree 225's? I have been thinking about using a full roller rocker but I just don;t know if i want to spends a 1000 buckks for what? 5 HP maybe??
So does anyone have before and after numbers??
Here is a thread where they give you the numbers between stock rockers and the Yella Terra Ultra Light rockers. http://forums.corvetteforum.com/show....php?t=1774947
P.S. You will need to buy the correct rocker stands for your ETP heads. I was able to use the rocker arm stands from Comp Cams for the RHS heads since they start out as ETP bare castings. I can't find what I did with the part number, but PM edcmat-l1, he knows the part number by heart.
For $390, Yella Terra Ultra-lights are a pretty killer deal...... Valve train stability, no worry of broken stock rockers and on reasonably radical camshaft profiles nice horsepower gains (8-12 rwhp realistically) on many setups.....
Just ordered a set for my 1300hp turbo LSx that I should of replaced the stock rockers long ago on..
As it looks right now ill have to run the Jesel J2K's and spend near $2k..... Im going to call up T&D also and see what they have since im running the new Warhawk LSX heads.
Kyle
Originally Posted by Jimmy P
The Yella Terras are not adjustable, and they will NOT work with the ETP heads.
im in the same boat now. Unfortunately, t&d's are on a month backorder, jesel's are still 1500 bucks, and one a week backorder... and im trying to get my motor back together with my brand new etp 245's and .700 drag springs. So... after a lot of research and homework, found the new scorpions are only 400 bucks, and getting great reviews. Talked to craig at etp, and he said they have put the scorpions on some of their heads, per customer request, and he said they do work, but they use a different shimming technique than most, its "ford shims". I would still love to stumble into some used jesels that are purpose built for my etp's, but in the meantime, im gonna give these scorpions a shot. Supposedly, the guy who put them on his heads has had no problems. Check em out, its an amreican company down in florida, they have really light tips too, and they are a roller rocker. part number is scp1098. Post up part numbers of other rockers for etp heads to make this thread more useful if anyone knows the others, thanks, brandon
It's also comp #1509 for the RHS head.
Dont forget that Crower makes a rocker arm for the ETP heads. Part # 75102. I think they cost me around $1150-$1200.
I recently purchased a set of ETP 225 heads for my 402 being built. I also bought the Scorpion rockers, and sent a pair to Craig for test fitting. Craig told me that they will work using a .060 shim.
Unless someone has a better suggestion, the Scorpions will be installed next week, anyone?
I would rather spend more if needed, and get it right! Suggestions?
