L92 vs LS3
Old Oct 3, 2007 | 12:43 AM
GoFast908Z's Avatar
Default L92 vs LS3
ok, there might be a thread on this, but we all know the search engine sucks....
I'm building up a stroked L92. Using L92 heads, L76 intake....
Am I really builiding a stroked LS3?
Old Oct 3, 2007 | 09:58 AM
Robin L's Avatar
LS1Tech Sponsor
Yes and no, Once you change the rotating assembly, cam, valves and springs it might as well be a LS3 that you used.
Some L92's didn't come with DOD. Those that did would require some changes in the lifters and lifter retaining trays as well as the valley cover.
I think ( I am not sure) that all L92 and LS3 have the cam phaser. If that is true you will need a LS2 Cam Sproket and LS2 Front timing cover also.
Don't forget the L92 uses the truck style waterpump and pulleys. All that would have to go if installed in a car.
Robin
