LSX cylinder wall length?
Below is a pic of the relationship between the oil ring land and the pin bore. We used a napier second ring in this ring package.
I'd appreciate any comments about this.
Richard
Next time I'll stick to my experience.
Richard
Richard
The practice of running the pin bore into the 3rd land is a last resort...only to be done if there isn't enough room for necessary dish volume or there isn't enough left over ring land thickness to support the horsepower (big nos, supercharged, etc). In racing applications, it's better to have oil consumption than piston breakage. Was I the person you consulted with at Wiseco about these pistons? If so, we haven't had negative feedback on the "pin in the 3rd land" previously, but email me at bnutter@wiseco.com and we'll see if we can get to the bottom of it.
-Brian Nutter-Wiseco Piston
For guys reading this thread thinking about a 4.100/4.125 crank; the 1.050 compression height piston with mandated .237 top and .140 2nd land (with standard pin placement) is fine on the street with mild boost. As long as the skirt shape is ok, oil usage shouldn't be bad. Guys running nitrous should limit it to a very small shot or go back to a 4" crank.
I have used several like that with the oil rail a little through the land with no problems or oil consumption. On mine the ring stack was shorter though and there was more slirt in the bore at BDC and I used a longer rod or it was on something with a longer sleeve etc. The stroker pistons I get from Wiseco and I always deal with Brian Nutter above have never had any issues at all but we did really take care in designing them and like was said on extreme power adders and with that shorter cylinder I usually use the 4.00 or even 3.900 crank on those.
I even have some larger stroke stuff in the iron blocks now we are working on that are NA only but seem to work great. They make even more tq and hp but the ring stack is too short for any big power adders at all.
