408 not making power
Old Oct 20, 2007 | 11:33 AM
White_Hawk's Avatar
Originally Posted by 408z28
I was asking in reference to your cc on the chambers, not your port work.
l92's came with 70cc chambers, I was getting an idea of your compession.
With a flat top piston and a l92 head you could only be @ +/- 10.0 to 1.
X2. You need more compression. Check you P to V celarance before milling. If you could mill off 0.030" and go with a thinner gasket you could get the compression up.
-Geoff
Old Oct 20, 2007 | 11:35 AM
White_Hawk's Avatar
Originally Posted by VDiddy
exhaust is 1 3/4 kooks full lengths and cats with cords cat-back. The chambers are stock size and piston has a small dish but my math puts this near to 11:1 compression with a 408.
I think your math is wrong too. Post up all the number you used in your calculation.
-Geoff
Old Oct 20, 2007 | 11:45 AM
LS1curious's Avatar
can you post up the dyno chart ? to me it sounds like the camshaft might be in way to early or to late. those valve timming events look about spot on for what I have been seeing works with this CI and those heads and intake.
Need some ideas ya'll.... I recently installed an iron 408 in my CTS-V with L92 heads, L76 intake and 236/238 cam with ~.600 lift and 114 LSA. It's not perfectly tuned but is right at 13.0:1 AFR at WOT according to Wideband and is running about 28 degrees Total advance. It's putting 435HP and 405 lbs./ft. of torque to the wheels. This seems WAY low to me according to what else I've seen out there. The motor makes pretty good oil pressure (around 30 lbs. at idle and 52 lbs. at 5000 rpm). It seems to run fine, nothing that would indicate compression or leak down issues... just not what I expected. Any ideas why it could be so off on power?
It does consume about a quart of oil every 1000 miles or so, but with no visible oil smoke out of the exhaust except at WOT high rpm...even then very little.
Old Oct 20, 2007 | 11:57 AM
edcmat-l1's Avatar
Originally Posted by slow trap
the l92/76 combos seem very picky about cam profiles. even with that cam (which probably needs 8-10 more * of duration on exhaust side) the power seems way low,especially on the tq side. what does your exhaust setup consist of ?
I agree. Very low even for a less than optimal camshaft.
Old Oct 20, 2007 | 11:59 AM
edcmat-l1's Avatar
-Geoff
Thats a real possibility too. Just got done tuning one I believe was much lower compression than calculated.
Old Oct 20, 2007 | 12:27 PM
408z28's Avatar
Thats the only reason I didnt buy the l92 heads for my last 408. Because with my -8cc dish I would be around 10.1 to 1. With the Dart 62cc heads, I went to around 11.2 to 1.
Old Oct 20, 2007 | 01:27 PM
Double-L's Avatar
To small of a cam, Why does Lingenfelter go with their GT2-2 cams for the stroked LS2's and their new LS3's, I had a LS3 built, Eagle balanced crank, H rod, JE pistons, Dart 225 heads, 112 super charger, Razor alky injection, So on and asked them what would be the best cam and they said right off the bat GT2-2 207/220 571/578 with 1.7 rockers, I have Comp 1.85's....
So my question is why is this cam to small when they are 9 sec. street cars running smaller cams than he has??
Old Oct 20, 2007 | 03:04 PM
VDiddy's Avatar
Guys, you may be right. I just re-checked everything... 4" stroke, 4.030 bore, cometic LS6 head gasket (I think it's .040 thick and 4.060 hole), 70cc chamber (stock L92 unmilled) and an 8cc dish. Harold zero decked the block. Looks to be about 10.66:1. Is that too low? What can I get away with on the street using 93 octance gas without pinging?
VDiddy's Avatar
also, If I ran 11.5:1 for example, how much more power would it make?
Old Oct 20, 2007 | 03:09 PM
LS1curious's Avatar
While compression can help with TQ output ultimately the most important thing about making Tq is Air volume. the more you have the more Tq you will make. It is possiable that the camshaft is missing the tunning length of the intake manifold runner system hence the low Tq output. Without some dyno charts and more detialed infromation on the problem I do not think anyone here will be able to assist further.
Old Oct 20, 2007 | 05:05 PM
slow trap's Avatar
i think with all things being equal a point in compression gains around 4 % more power give or take. something is out of whack other than your scr.
Old Oct 20, 2007 | 05:23 PM
  #32
cryptnosis's Avatar
Have you tried ripping other tunes to your engine? I was having some problems similar to that, i got p&p ls1 heads, and a 232/232 cam, i am putting 450/475 on paper. If you want i can send you my tune. Also, on HPT website, there is a rip from a 1999 z28 with a 408 with texas speed tune for m6, rip that one to see how it runs, just my input
Old Oct 21, 2007 | 01:43 AM
  #33
ZLEEPER's Avatar
This seems alot like the issues I was having with my 402. L92/L76 etc..
I was runnig a similar cam (slightly bigger) and putting down around 470/455 to the wheels. Added a catch can set up (search "see5" posts) which eliminated the oil consumption issue. Car is at ICON right now getting a bigger cam put in along with some kooks 1 7/8's headers. I expect alot more this time around.. Will let ya know.
Old Oct 21, 2007 | 07:34 AM
  #34
edcmat-l1's Avatar
There may be a little left in the tune. Theres ways of figuring out if your comp is low too, without pull the motor apart.
https://ls1tech.com/forums/dynamometer-results-comparisons/802086-thank-you-ed-hutchings.html
Old Oct 21, 2007 | 07:36 AM
  #35
edcmat-l1's Avatar
When it comes to L92s and cams, bigger is usually not better. Putting a bigger cam in may be a mistake. Th 1 7/8 headers are a good idea though.
Old Oct 22, 2007 | 06:57 AM
  #36
VDiddy's Avatar
I wondering now if the pushrods I had for my LS6 heads, which I'm now using on the L92s, are too short. Something tells me I'm not getting all the lift at the valve that I should be. Or, maybe the CTSV-R lifters are shorter or the base circle of my cam is shorter? Anyone else ever experience one of these things? The car doesn't feel like it's down a cylinder, I'm pretty in tune with the sound and feel of 8 cylinders vs. 7.
Agree that there is more power potential in the tune...just not 60-70 horsepower and that much more torque. Something else must be wrong.
The catch can is a great idea for stopping the oil burning through the intake...I'll have to try that. Maybe the intake charge is severely polluted with that much oil going through there? I'M PULLING MY HAIR OUT!!! ARGHHHHHHHH!!!
Old Oct 22, 2007 | 07:16 AM
  #37
fastbasser's Avatar
I am far from an expert.. In my 402/L76/L92 motor, I just used the cam out of my 427. It is a 240/240 @.050, .608/.608 w/114. With 11.5 cr, I make 502/476 thru my A4..
The cam can make a difference. Thats alot of difference though.. If all is assembled right, I would try loading up a different tune before I start messing with the motor..
JMHO
Old Oct 22, 2007 | 07:30 AM
  #38
VDiddy's Avatar
Do you have HP Tuners? Could you send me your tune as a baseline so I can see if it makes more power? I am using the Lingenfelter mass air meter though... will likely screw up everything.
Old Oct 22, 2007 | 07:57 AM
  #39
Deeavi's Avatar
Take it to a professional tuner.
Old Oct 23, 2007 | 08:06 AM
  #40
Stang's Bane's Avatar
You may have something there with the pushrods.
By Brett Foote | 2026-06-04 05:00:17
