High Compression Race Motor Opinions needed!!!
-LSX Block
-Most likely a 4.185" Bore and a 4" stroke yeilding 440ci
-13.5:1 CR
-Either All Pro LS7's or ET's C5X inline valve race heads
-Sheet metal intake
-Solid Rollor
-Adjustable jessels
I am also considering SB2.2 setup, but know very little about the gen 2 small blocks
If somebody could suggest an intake, heads, bore and stroke size, builder, estimate on price, and any other info about this setup I would probably consider it more.
Coming from road racing bikes for many tears, you always build the setup to the maximim potential of your class. You dont build something just to be able to say you've got a high compression, big displacement, race motor. Cause you'll end up becoming a back marker on the track and just get in the way.
I would say step down in class, then take the avail money to build the BEST you can build.
-LSX Block
-13.5:1 CR
-All Pro LS7's
-Beck Sheet metal intake
-Hyd roller
-Not sure if I want to go carb or efi
