Convince me to build LS instead of BBC!!!
Old Nov 13, 2007 | 02:54 AM
  #181
1997bird's Avatar
Ed, what happened to my pristen SS? I go home a few thousand miles and this is what I see, son of a @**!. But hey I guess I got a cool sticker!! Just kidden.
Old Nov 13, 2007 | 07:28 AM
  #182
edcmat-l1's Avatar
OOPPSS!!!
Old Nov 13, 2007 | 09:52 AM
  #183
ty_ty13's Avatar
7 Second Club
i say 555 or 565 for cheapness and power... then put the giggle juice on it... i started from scratch again i'd do another 555 with the juice... its just too easy and too cheap compared to these lsx forced induction motors...
Old Nov 13, 2007 | 10:01 AM
  #184
gearhead1186's Avatar
nitrous and retard shuld both be at WOT? do u want to leave on nitrous shot? or does the progressive control take car of this?
wow thats a 10 point cage and then some... since im new to this can somebody briefly go thru wat is necessary to be certified to run up to 8.5.. thanks..
Old Nov 13, 2007 | 01:56 PM
  #185
Quickin's Avatar
Originally Posted by edcmat-l1
Ok, heres my productive contribution. This is an EFI 540 in our shop right now. With a fogger. With these solenoids, shes only good for a 250 shot. Thats all the customer wants. With nothing more than changing the solenoids and the jets, its good for up to 500. Its not very complicated, nothing that hasnt been done before. You dont need a second set of fuel injectors. You could run a dedicated pump, cell, and lines, just for the spray, and have your race gas right there. The cell could be real small. 1.5-2 gallons. Something also readily available. The triming retard is also pretty simplistic. Nothing more than a timing retard activated by the WOT switch.
As for a chassis that will legally go in the 9s, theres regulations, specifications that you'll need to build to. 7.5-9 seconds is not a "class". The cert to go 9s will cover you to 8.5. Anything faster than that is a whole diff ball o' wax.
If you want I can post some pics of the last cert 8.5 chassis we built.
There ya go "gearhead", do what he says.
edcmat,
Is there something that will shut down the spray if it detects a lean situation to save from a meltdown? As well as another system that will shut down the fuel spray so you don't hydra-lock from all that additional fuel going in?
Also, something that will save your engine if it detects a rich condition, or again a hydra-lock, if the spray stops spraying for whatever reason?
In short.....is there something that will save the engine from any type of nitrous mishap?????
Q
Old Nov 13, 2007 | 02:06 PM
  #186
ty_ty13's Avatar
7 Second Club
you need to have someone local help you build this or it will be a disaster...
Old Nov 13, 2007 | 03:16 PM
  #187
i kno there is a safety that works off ur fuel pressure.. if ur pressure is below a limit it will cut out the nitrous..
im also interested if there is something that will do the opposite as quickin said...
Old Nov 13, 2007 | 03:19 PM
  #188
i dont want to bore it out too much.. 4.5 is enuf for me.. never can have too much insurance.. plus room for future builds
Old Nov 13, 2007 | 03:42 PM
  #189
edcmat-l1's Avatar
No need to worry about a safety if only fuel sprays. In other words, in event of nitrous failing to spray. The motor wont hydro-lock, it'll just fall on its face and run like ***.
Old Nov 13, 2007 | 04:16 PM
  #190
pist0lpete's Avatar
You can get something called an air fuel ratio safety switch. It works in conjunction with a wideband and you set your target af ratio and if it goes outside that target area it shuts off the nitrous system.
Old Nov 13, 2007 | 04:59 PM
  #191
ahh i love how there is always a gizmo.. is this necessary or would a fuel pressure sensor like i mentioned b4 be enough?
Old Nov 13, 2007 | 08:19 PM
  #192
edcmat-l1's Avatar
Most of the guys running any amount of spray, all heed the KISS theory. That is Keep It Simple Stupid. Nobody is running anything more than a progressive controller. And alot of the top sportsman, Quick8 guys dont even run them. Most just run multiple stages run by timers. I'm not talkin about guys running a 150-200 shot, I'm talkin the guys running 400, 500, 700+ worth of spray. Some guys run the progressive controllers, some guys hate em.
The whole deal with nitrous is the bigger the motor, the more spray you can run through it safely. That doesnt mean you cant hurt a big motor with a failure of some sort, but it does mean that a 540+ inch motor can handle a bigger shot, say 350-400 repeatedly with less chance of damage, or frequent rebuilds.
Old Nov 13, 2007 | 08:47 PM
  #193
Greg Fell's Avatar
2nd the K.I.S.S.
Old Nov 13, 2007 | 09:15 PM
  #194
I dont kno im misinterpreting this or not but are you saying that a nitrous motor will be prone to more damage and will need to be rebuild more frequently than another motor even if the system if working properly?
Old Nov 13, 2007 | 09:27 PM
  #195
edcmat-l1's Avatar
Dont know how you can misinterpret that. A bigger motor purposely built for nitrous will withstand larger shots of spray with less damage, wear and tear, than a smaller motor built for spray. Larger volume engines can handle larger volumes of nitrous.
Old Nov 13, 2007 | 10:26 PM
  #196
no i understand a bigger cube inch motor can handle a say a 400 shot better than a smaller cube inch motor. but u said it has a less chance of damage and frequent rebuilds. by this does it mean that a big nitrous shot on a big cube motor still has a potential to be damaged and rebuilt even if its done right?
Old Nov 14, 2007 | 07:49 AM
  #197
edcmat-l1's Avatar
Theres always a possibility of hurting something. Even with a NA motor, you can break stuff, blow up, whatever.
NASCAR engines cost in the range of 80 grand, and they blow up every once in a while.
Old Nov 17, 2007 | 06:30 AM
  #198
toneloc60's Avatar
Nitrous is a great way to have a mean street car that can get even nastier for the track. I love it, and I think you're on the right track here.
Just keep in mind that even with the most careful consideration of parts and combinations, Murphy always has a say. So, if I were in your situation, I would build the engine ready to handle N2O and run a fogger system set up for a smaller shot to get used to it. Then work your way up to the bigger jets after getting comfortable with the car and reading your plugs.
What I think edcmat was talking about was the inevitability that things can and do go wrong. You can build the engine to last and still have a failure. That was all.
