L92 guys... what rockers?
Old Nov 5, 2007 | 01:55 PM
508Stroker's Avatar
Default L92 guys... what rockers?
Is anyone making any after market rockers for the l92 heads yet? Are you guys just using the stock ones in all the built motors I see around here? Do LS7 rockers bolt up? Thanks guys.
Old Nov 5, 2007 | 04:35 PM
Pwebbz28's Avatar
Ls7 rockers do not bolt up. T&D makes a set of shaft mounts as does jessel. I went with some custom T&D's for my setup.
Old Nov 5, 2007 | 05:24 PM
508Stroker's Avatar
Nice. I have had good luck with their products in the past. How much are they?
Old Nov 5, 2007 | 06:36 PM
ZLEEPER's Avatar
I had a set of stockers fortified by Harland Sharp.
Old Nov 5, 2007 | 06:37 PM
jay_lt4's Avatar
stock L92 on mine,, so far so good,, and they are only $7.00 each
Old Nov 6, 2007 | 09:12 AM
508Stroker's Avatar
how much power are you making?
Old Jan 25, 2008 | 11:48 PM
jay_lt4's Avatar
not sure, but my engine is the exact same as this carcraft build and they made 550 hp at the flywheel:
http://www.carcraft.com/techarticles...ads/index.html
Old Jan 26, 2008 | 12:04 AM
TT LS2 1969 Camaro's Avatar
Hey!
Yella Terra makes a set of rocker arms for the L92 in different ratios... Very good product. Can't wait for mine to arrive.
Old Jan 26, 2008 | 02:01 PM
VortechC5's Avatar
When you get them installed please let us know if they clear everything without having to grind on anything.
Originally Posted by TT LS2 1969 Camaro
Hey!
Old Jan 26, 2008 | 09:58 PM
RGKSR's Avatar
Default Stock Rockers w/Harland Sharpe Upgrade!
I did the same thing!
Bob K.
Old Jan 27, 2008 | 07:48 AM
WKMCD's Avatar
I replaced my stockers yesterday with the Yella Terra Ultralights. We didn't pick up anything noticable on the dyno but I did it more for reliability. I run the GMPP bowtie valve covers and nothing hits.
Old Jan 27, 2008 | 02:36 PM
VortechC5's Avatar
Cool, so they cleared everything. Did you have to change pushrod length?
Old Jan 27, 2008 | 03:11 PM
WKMCD's Avatar
Same pushrods. I'm not sure if they would hit anything on stock valve covers - I'm not running them.
Old Jan 27, 2008 | 03:13 PM
VortechC5's Avatar
I have the Katech valve covers on so clearance won't be an issue on mine either.
Old Jan 27, 2008 | 03:21 PM
Please do explain the fortified procedure, as I am curious to know what they did....Thanks!
Old Jan 27, 2008 | 07:13 PM
03 BUSA's Avatar
Stock 98 for the exhaust and stock L92 on the intake. Holding up fine with over 550 horse
Old Jan 27, 2008 | 08:17 PM
supersub's Avatar
12 Second Truck Club
Harland sharp full rollers here!
LSX427 588hp/532ft lb's tq fitting under the stock cover's
Old Jan 31, 2008 | 11:21 AM
Just curious to know if these rockers adjustable?
Old Jan 31, 2008 | 11:38 AM
ScottyRocket's Avatar
Looks to be only pedestal height may be adjustable on those.
Old Jan 31, 2008 | 07:56 PM
drain89's Avatar
I'm gonna go with the yella terra ultra lites.
