402 stroker build
Before you go with -2cc pistons figure out what heads you want to go with and get your combustion chamber the right size. Then look at your SCR, DRC, and valve events and make sure your compression is correct. I had to go with 58cc chambers with -12cc pistons to get 11.5:1. If you are going with -2cc pistons you might have to go to a 72cc chamber and mill from there. It might be better to use less volume in the piston and keep the combustion chamber smaller. The longer stroke really boosts the compression. More swept cylinder volume going into the same size chamber gives a higher compression ratio.
JMHO. BTW, I really like my 403. I can't wait to put my foot into it.
