L92 heads
Old Jan 8, 2008 | 08:40 PM
supersub's Avatar
12 Second Truck Club
Call randy Jr. over @ harland sharp,he will set you up.BTW Minor machining WILL be required for clearances,WCCH includeds it in there cnc programs on the L92's.
Old Jan 9, 2008 | 01:40 AM
Hans Grüber's Avatar
Can you post pics of the head modifications required?
Old Jan 9, 2008 | 10:54 AM
Richard@WCCH's Avatar
Here' you go:
Richard
Old Jan 9, 2008 | 11:16 AM
Stang's Bane's Avatar
Originally Posted by AU N EGL
I know I dont have the whole picture, but what is the TQ like from 3000 to 4100 RPMs?
Is something like this going to take off slow, then kick in at 4200 up to 6400 rpms?
TIA
VTEC!!!
Old Jan 9, 2008 | 12:09 PM
BES Stroked Nova's Avatar
PRC L92's are going on a 6.0L shortly... and you might as well get the LS3 valves.
Old Jan 9, 2008 | 12:36 PM
black_z's Avatar
LS3 intake valve is different, LS3/L92 exhaust valves are the same.
Old Jan 9, 2008 | 02:54 PM
Thanks for posting that Richard, does the rocker cover have to be modified as well?
Old Jan 9, 2008 | 06:08 PM
Not to my knowledge. They should fit right on.
Good luck,
Richard
Old Feb 5, 2008 | 08:05 PM
OnyxSilveradoSS's Avatar
is there an assembled head using the LS3 valves?
Old Feb 12, 2008 | 01:02 PM
Red Goat's Avatar
Default L92 heads
What is the rocker ratio on the L92 heads on the 6.0 with stock springs?
Old Feb 12, 2008 | 01:52 PM
WKMCD's Avatar
FYI - I just installed a set of Yella Terra Ultralights in my L92's with no interference problems.
Old Feb 12, 2008 | 06:27 PM
  #32
RAGENZ28's Avatar
Can we get some flow ratings, intake and exhaust charts?? Stock head/stock valves vs. some of you sponsors ported, cnc ported and with various valve sizes?
I wanted to use these on a 402 or 408 with a F1A Procharger for my 800-900 rwhp pump gas monster =)
Old Feb 12, 2008 | 06:50 PM
  #33
prince_ws6's Avatar
Originally Posted by JDP
anything with a 4in bore
yes hes right
Old Feb 12, 2008 | 07:20 PM
  #34
Johny GTO's Avatar
it seems the L92 heads only show there worth on stroker motors over 402ci.
on stock cubes, they dont seem to perform to well.... well i should say they perform on a level under stock port and polished ls6 heads and after market heads.
yes?
Old Feb 13, 2008 | 10:58 AM
  #35
black_z's Avatar
Well, cam only LS3 vettes are making 475+ RWHP. If you get the VEs correct, they will make great power.
Old Feb 13, 2008 | 11:21 AM
  #36
slt200mph's Avatar
Cam, headers, vararam, and a tune are doing well over 500+ rwhp in LS3 Vettes..
Old Feb 13, 2008 | 01:59 PM
  #37
Johny GTO's Avatar
then what is the problem with these heads on the ls2's?
they dont come near that without loads of work.
what needs to be done to get the same results on an ls2, cause it seems that the people tunin and building these arent getting the VE's right, i guess??
Old Feb 13, 2008 | 02:03 PM
  #38
slt200mph's Avatar
The LS3 heads are far superior to the LS2/LS6 heads for the most part. The additional cubic inches don't hurt eithere..
Old Feb 13, 2008 | 02:42 PM
  #39
AU N EGL's Avatar
That is the theory, but so far on the T1 road race LS3 Vettes arn't getting that.
Old Feb 13, 2008 | 02:50 PM
  #40
WKMCD's Avatar
Who cares about facts. This is the internet where everyone makes over 500RWHP.
