Coolant Crossover tube for high HP setup
Those small hardlines can't be more than .125 - 1/8 inside diameter, Since it handles has all 4 ports in the original design. I figured thats pretty low flow.
Ed
But it wouldn't account for any crossover from driver's to passenger side.......would that be an issue?
11-14-2007, 11:16 PM #6
bigdsz
Trader Rating: 1
We just put a HK Racing 408 in my Camaro and I was concerned about the rear steam vents because two of my friends recently wiped out #7 and I didn't want to take any unnecessary risks.
Anyway I used some of my old LS1 steamtubes and cut the tube so that there was about 1 1/2" sticking out from the flange that is bolted to the head. Then I used a SS tee and ran a 5/16" id line up to the front cross over and connceted it with a tee which I ran to the radiator.
It is absolutely amazing how much coolant those little hoses flow. I truly believe that these tubes also bleed off steam-air pockets that could cause hot spots. I sure have alot more peace of mind.
FWIW my last project on my 408 was installing an engine oil cooler. It was a bitch but necessary since my oil temp was getting up to 270-275. Now most of the time I stay below 200 unless I romp on it.
__________________
'09 Corvette
'04 Corvette-Sold
'00 Z28-HK Racing 408, Callies Dragonslayer Crank & Rods, Wiseco Pistons, AS Stg 2 5.3L heads, Comp XER 244/248, FAST 90 intake, NW TB, Lingenfelter 100mm MAF, Racetronixs PNP, SVO 30#, March pulley, SPEC Stg 4+, McLeod bellhousing, Fast Toys lid, Jet Hot headers ORP, Hooker cat back, Pro 5.0, Denny's Nitrous DS, Norris LS1 Edit, Strange 9" center sec./Detroit soft locker/3.50 gears/Moser housing, Hoosier QTP's, UMI K member, A arms & reloc brac.
HTH
There's been a total of 10 part number changes over the years. Crazy.
Those custom plugs with the threaded holes from Wegner Automotive are a good way for guys to go that still want to run lines to the rear of the heads.
Kurt
