Coolant Crossover tube for high HP setup
That way the cycling fluid will be just that...fluid.. as it goes back into the radiator/cooling system as needed.
Thought I'd post this to clarify some of the part numbers that were listed in this thread that I discovered were incorrect (not bashing anyone here, just trying to help clarify). After researching this until my eyeballs fell out, here's what I found:
12604711 is the two port setup from a truck engine. From what I can tell, it is the replacement for the 4 to 1 setups that used to come on the trucks. It has its outlet pipe in a different location than the LS1 pieces do. This one comes out of the driver's side head connection. It also needs the rear block offs. From pics I've seen from another member, they did make 4 to 1 truck setups, and they also had their outlet connection on the driver's side head connection too. As far as I know, the 4 to 1 for trucks has been discontinued. Here's the drawing for a two port truck piece, tag# 307:
12604711
12602544 is the two port setup from the 5.7 cars. From reading its description, I'm taking it that it is the replacement for the old style 4 to 1 setup and requires two plugs. It has its outlet connection offset from the middle of the crossover pipe between the two head connections. The drawing shows it drawn as a 4 to 1, but when you read the description, it is listed as a two port setup that needs to rear blocks. It doesn't mention any superceded numbers either, but I'm thinking the 4 to 1 is no longer made as a buyable part. If you search out LS6 cars, the picture shows a two port setup in the drawing, and the PN is 12602544. If you search out a 98 and up LS1, its drawn as a 4 to 1 but the PN is listed the same as the LS6 stuff, which is 12602544. See here in a 98 drawing. The part is tag# 538. Drawn as 4 to 1, but listed as two port:
12602544
The only one I cannot locate, is a piece someone else mentioned on here. The number is 12557538. I do not know for sure if it is even a coolant line. And if it is a coolant line, I don't know if its a truck or LS1 setup. But from all the drawings I looked at and PNs I've searched out, its my guess that they do not make the old style 4 to 1 pieces anymore. Even when you search for a coolant crossover from a 97 up car, it comes up with the same drawing as 538 above. I have not found a drawing with a 4 to 1 part number listed, so I'm guessing they are not available anymore.
Anyways, 12604711 (two port truck) and 12602544 (two port LS1) are readily available at GM parts stores, Summit, eBay, etc. If you want a 4 to 1, you gotta go used.
If you need the little oblong washer/o-ring setups, they are PN 12551933 which are about $6 each.
Hope this helps someone sooner or later.
It's circled in yellow.
http://m.modmotortech.com/forums/sho....php?t=1342636
Thanks for the info.
At least on the F-Body..............
I'm wondering if you took the single out tube in the front that goes over to the radiator....and ran it to an aftermarket stacked type cooler and mounted it somewhere, then ran the out line from that cooler to the normal radiator port, if that would help drop coolant temps over all. You could put a pretty decent sized cooler mounted to the back of the fans.........
There is a reason they did it on the LT1s. I believe that better reliability and possibly performance can be obtained by using them. I have installed numerous ones on quite a few builds. IMO anything supercharged or turbo should use it, and really if you can justify the cost, any other street engine. It eliminates the possibility of steam building up at the rear caps or air pockets being trapped. And more even distribution of water means more ability to keep a constant temp from cyl to cyl (as far as coolant is concerned).
Plus with a few diff systems, you can run either 3 an or 4 an line, helping out the "high flow" characteristic the OP was looking for.
Even though most of this was covered in the previous posts in this thread, a quick recap never hurts for those just looking at the last page of this thread.
