Any bad experiences with SDPC or SLP 402 LS2?
A local vendor gave up on mechanical work halfway through my LS2 build, another local vendor wants $2,500 for assembly and machining which brings a LS2 shortblock using my old H-rods and chain and used stock crank to about $4,300.
SDPC $4,349 + shipping (TX to CA) - Eagle crank, Manley pistons, Scat rods, includes front cover, cams sensors, valley cover, HD Single row timing set, timing chain dampener, crank key and the necessary block dowels and plugs
http://www.sdparts.com/catalog/lsgen...kAssembly.aspx
SLP $4,595 + free shipping - [Edit: Callies crank, Manley pistons, Manley rods], does not have timing chain, camshaft, pans, plates, and covers
http://www.slponline.com/view_product.asp?P=12413M
Tbyrne SLP $4,135 + shipping (MA to CA) - same as SLP
As for the SDPC, I did an install with a friend on his car and had great results, untill a vavle on his AFR heads snapped off and killed it.
https://ls1tech.com/forums/removed-locked-thread-graveyard/438868-warning-slp-402-defective.html
...and...
https://ls1tech.com/forums/removed-locked-thread-graveyard/438868-warning-slp-402-defective-3.html#post4110946
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
What type valve broke? I have LS3 heads (mildly ported with sanding rolls) with comp 921 dual springs, Manley stainless intakes and stock exhaust valves.
SAE 495RWH/489RWT
Car runs beautifully
I like the SLP short because it has better parts in it for the money.
that post made no sense ,quote ,i like SLP Better because it has better parts for the money unquote ,He apparently didnt read the post that sdpc put in ,i personally have a Tsp 402 that is on its way from tsp,i would not hesitate to do buisiness with them ,they know what there doing ,also some people hear may have had bad experinces with vendors on this board,that doesnt mean that u will ,u just need to pay attention to whats going on with your motor ,if u want to run Fi ,make sure you are gonna get a set of pistons that will hold up to your application,Basically what i am trying to say is dont skimp out on your build
Compare the basic kit from SLP and the basic kit from SD
U get a better crank,rods and pistons in the SLP STANDARD
For ADDITIONAL money u can get the better parts in the SD piece
I think u owe me alittle,I'm sorry
