LS2 harmonic balancer’s location not marked when removed
Is it critical to put it back on in its original position?
How can I determine its proper location to place it back on the crankshaft?
What is the purpose of the 2 sets of 4 holes on the outside edge balancer… timing, weight?
There was no washer between the harmonic balancer and the large bolt securing it to the crank. I had read to add a washer, is this true? I will be using an ARP bolt not the OEM.
Any comments regarding adding a washer for the ARP bolt?
